  • July 15, 2025, 07:29:23 AM
Author Topic: Perky Question  (Read 5277 times)
Offline Jim Carter
Perky Question
« on: August 03, 2018, 05:03:45 PM »
Greetings y'all!!  Gott'a couple of questions about Perkys and I need some advice.  I'm in the process of building a new one so I can claim the world speed record ;D
1.  I know tuned pipes are not allowed so how should the exhaust of a rear exhaust motor be ducted to avoid having the exhaust dumped inside the cowl?
2.  Is it required to use the upper cowl for a flight?
I'd appreciate any suggestions/recommendations.
Jim Carter
Re: Perky Question
« Reply #1 on: August 03, 2018, 06:37:28 PM »
You can use a straight pipe to get the exhaust out.
I think you could use a tuned pipe, too, but it probably won't help considering the standing start.
Offline Jim Carter
Re: Perky Question
« Reply #2 on: August 04, 2018, 09:56:56 AM »
Thanks Paul!
This was the reason I asked: based on the  "November 6, 2007 NASS Perky OTS Speed Rules Reviewed and approved by NASS Technical Director to ensure compliance with AMA Safety rules.   7.  No Tuned Pipes or Megaphone exhaust extensions allowed. Mini Pipes and Mufflers are ok.
Lastly, does one have to use the upper cowl?
Jim "World Perky Speed Champion" Carter
(Hey .... don't wake me up .... a fellow can dream can't he?? )
Offline bob whitney
Re: Perky Question
« Reply #3 on: August 04, 2018, 10:17:37 AM »
send me your email and I will send u a couple of pictures of a mini pipe set up
rad racer
Offline Jim Carter
Re: Perky Question
« Reply #4 on: August 04, 2018, 03:37:28 PM »
Done!  Thanks in advance.
Offline Jim Carter
Re: Perky Question
« Reply #5 on: August 04, 2018, 03:52:45 PM »
I wanted to make one that was profile and everybody gave me hell so yes, you have to have the cowling.
Motorman 8)
Well, as a profile model, I can see what the objection was but given the fact that the rule #1 states: "The Model must be built to the out line of the original 1946 Megow Perky design. Construction modifications allowed."  However couldn't one be built using say a Dave Brown motor mount in the sidewinder configuration?  I believe that would be allowable since that's exactly how my next one will be built  ;D!!
Offline Dave Evar
Re: Perky Question
« Reply #6 on: August 04, 2018, 04:57:28 PM »
Attached is my first Perky.  Conquest .15
Two average speed trophys, now retired.
Formed aluminum roofing flashing to direct
exhaust and hold down rear of cowl.
Brooklyn OH
North Coast Control Liners   Find us on Face Book
Bean Hill Fliers, Albion PA Akron Skymasters Control line Association  Gone, but not forgotten.
Offline richardm
Re: Perky Question
« Reply #7 on: August 11, 2018, 09:18:29 PM »
Is this still a postal event?
And...........where can I get a plan or patterns
Where are the rules or are there any apart from .15 no pipe?
Richard Mc Fadden
Re: Perky Question
« Reply #8 on: August 12, 2018, 10:37:20 AM »
Yes there is a "postal" event again this year.  But there's no need to use US Mail.  Just "post" your scores here.
Re: Perky Question
« Reply #9 on: August 12, 2018, 10:39:52 AM »
The 2017 winners:
Bob Whitney is in the lead as of today with 116.85 MPH.
I have seen no scores from the AMA Nats.
Offline Jim Carter
Re: Perky Question
« Reply #10 on: August 12, 2018, 12:55:41 PM »
Man, that's nice!  Wish I could make mine look as good!  I have a Conquest 15 r/c but it's a side exhaust and the muffler is pretty good sized so I decided not to build one for it although I believe it should be a pretty good performer .... just heavy with that muffler  :-\!
Offline Jim Carter
Re: Perky Question
« Reply #11 on: August 12, 2018, 01:03:42 PM »
Paul, don't 'git upset wit' me but post scores??  Where?   ??? :-\
Re: Perky Question
« Reply #12 on: August 12, 2018, 04:33:10 PM »
Post 'em here.  Right on this here web site.
Then  I add them to this Excel spreadsheet.
Offline richardm
Re: Perky Question
« Reply #13 on: August 12, 2018, 05:35:28 PM »
Cool
Where do I find the rules ...line length I assume standing start by thge numbers wheel diameter, nitro? pressure?
I have a couple of .15s some will run on pressure only  :o
Richard Mc Fadden
Offline bob whitney
Re: Perky Question
« Reply #14 on: August 12, 2018, 05:38:33 PM »
the conquest can be made rear ex by turning the sleeve and housing 90 deg to the rear, no need for a muff
rad racer
Offline bob whitney
Re: Perky Question
« Reply #15 on: August 12, 2018, 05:45:12 PM »
Cool
Where do I find the rules ...line length I assume standing start by the numbers wheel diameter, nitro? pressure?
two  .014 solid lines 52.6 long  two 1 1/2 in wheels ,no pressure .1 3/8 to 1 1/2 spinner .outline needs to match the perky plans
10% nitro
rad racer
Offline Dane Martin
  • heli pilot BHOR
Re: Perky Question
« Reply #16 on: August 12, 2018, 10:45:52 PM »
I thought I posted the perky scores in my other post, but I guess I missed them. Here's the board from the Nats. Courtesy of Joey Mathison.
Offline Jim Carter
Re: Perky Question
« Reply #17 on: August 13, 2018, 07:43:09 AM »
KOOL!!  Paul .... you 'da man!! ;D ;D
Offline Jim Carter
Re: Perky Question
« Reply #18 on: August 13, 2018, 07:47:14 AM »
Yo!!  Dane!!  Jus' curious .... how did that "Pinky" Perky ever perform for ya' ??
Offline Dane Martin
  • heli pilot BHOR
Re: Perky Question
« Reply #19 on: August 13, 2018, 08:38:48 AM »
I'll let you know soon. Lol. Still haven't flown it. But I need to get an official this year
Offline Jim Carter
Re: Perky Question
« Reply #20 on: August 13, 2018, 03:38:42 PM »
LL~ LL~ Shucks, at the rate you're going, I bet I get mine in the air before ya!  ;D ;D  It may not be faster  %^@ but it'll be "firster"!!   LL~ LL~
Offline C.T. Schaefer
Re: Perky Question
« Reply #21 on: August 14, 2018, 05:43:57 AM »
Looks good Mr. Jim.  Tip. Get the wheels farther forward so she doesn't flip on landing. Also set the tailskid so the wing has only a couple degrees of incidence.  This is from experience.  TS
Offline Jim Carter
Re: Perky Question
« Reply #22 on: August 14, 2018, 09:40:22 AM »
Thanks for the kind words and the heads up Mr. Schaefer :) !  Around here, we fly off grass (about 1-1/2 to 2" generally) so with the "legal" size wheels, flipping on landing is almost a natural, expected result for a Perky flight cause mine glide about like a brick ;D LL~!
Offline Jim Carter
Re: Perky Question
« Reply #23 on: August 14, 2018, 11:20:40 AM »
Where did you get that UCTAM .15, is it abc? Is it supposed to be a Rossi Mk3 copy?
Motorman 8)
Greetings!  Would you believe, I got lucky and bought it from a fellow from the Ukraine on Ebay.?  Think I paid $35 or so.  It looks pretty good but I have to admit, I haven't run it yet. Don't know about it being ABC but it does look very close to the Rossi 15 that I bought off EBay a couple of years ago and mounted on my scratch built version of Da' Blob, an F2C trainer.  Man, that thing is a screamer!!
Offline Jim Carter
Re: Perky Question
« Reply #24 on: August 14, 2018, 11:24:00 AM »
10% nitro
Thanks Bob.  Forgive the slow response.
