  • July 31, 2025, 08:58:54 AM
Author Topic: Perky Fuel?  (Read 2895 times)
Online Dave Rigotti
Perky Fuel?
« on: May 23, 2021, 11:07:02 AM »
The current rules specify 10% spec control line speed for the fuel to be used.
These are: "Fuel for two-cycle glow plug engines shall contain 10% nitromethane, 20% lubricant, and the rest shall be methanol."
My question... Is the 20% lubricant all synthetic or castor or a blend?
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline bob whitney
Re: Perky Fuel?
« Reply #1 on: May 23, 2021, 06:08:47 PM »
i am fairly sure the nats will be 50 /50..for your own flying anything as long as it is 20%,i would suggest at least 5%caster
rad racer
Online Paul Smith
Re: Perky Fuel?
« Reply #2 on: May 24, 2021, 07:55:20 PM »
In my limited Nats speed experience, you have two jugs to chose from:  0% nitro and 10% nitro.  The same for everybody.
These guys value their engines, so the oil will be good.
Offline bob whitney
Re: Perky Fuel?
« Reply #3 on: May 24, 2021, 10:23:14 PM »
zero nitro is only supplied for F2A
rad racer
Offline Bob Heywood
Re: Perky Fuel?
« Reply #4 on: May 25, 2021, 08:03:25 PM »
NASS Special Blend spec fuel is 10% Nitromethane, 20% Lube (15% Synthetic / 5% Bakers AA Castor), and 70% Racing Methanol.
It's a safe bet Ritch's Brew will be the NATS supplier this year. I placed an order with SIG for St. Louis & Dayton and was told the fuel was backordered TBD.
"Clockwise Forever..."
Online Dave Rigotti
Re: Perky Fuel?
« Reply #5 on: May 25, 2021, 08:22:32 PM »
Thank you Bob!
Dave Rigotti
AMA 66859
Chesterland, Ohio
