  • July 15, 2025, 09:29:11 PM
Author Topic: Perky  (Read 1608 times)
Offline John KruziK
Perky
« on: October 19, 2008, 03:07:06 PM »
What fuel tanks are you guys using on these planes? Thanks John
AMA 874027
Online Paul Smith
Re: Perky
« Reply #1 on: October 20, 2008, 07:18:09 AM »
Here's a hint:
Clown racers with (unlimited) 15's can go 40 laps or more on ONE ounce.  So a little more than a 3/4 of an ounce should be enough to start it yourself, run out to the handle, and fly 16 laps.   A half-ounce if somebody starts it for you.
Offline John KruziK
Re: Perky
« Reply #2 on: October 20, 2008, 06:38:21 PM »
Thanks for info ...but is there a readily available tank to fit in that small space  Thanks
AMA 874027
Re: Perky
« Reply #3 on: October 21, 2008, 09:38:22 AM »
Check the Brodak web site or make the tank yourself.  It isn't that hard to make.  DOC Holliday
Offline LARRY RICE
Re: Perky
« Reply #4 on: October 21, 2008, 10:15:34 AM »
There is a ready made tank that fits between the engine and the firewall, and some, wanting extra fuel cut a hole in the firewall and pass the tank through it. Two good people to ask: Frank Carsile and Joe at Sam's Stuff and Hobbies.
Larry
Online Paul Smith
Re: Perky
« Reply #5 on: October 21, 2008, 12:23:23 PM »
Building your Perky is a good chance to learn how to make your own tank.
Fashion a wood block the size of your tank out of pine or some such soft wood, then wrap sheet metal around it.  Brass shim stock, .010" is what I always use.  The Perky is a good "tank trainer" since it doesn't need to stunt or go inverted.
You get four sides with one continous wrap, the add the two end plugs.
The third picture shows a tank form being sawed to size & shape.  The dowel was inserted 'cause I was chicken to get my fingers in the buzz saw.
« Last Edit: October 21, 2008, 03:56:18 PM by Paul Smith »
Offline Dennis Saydak
Re: Perky
« Reply #6 on: January 25, 2009, 03:19:52 PM »
About a dozen of our club members are building Perky's this winter. I couldn't find an acceptable tank for mine locally so I built one. Notice I lowered the motor mounts 1/4" so that the engine is mounted on the thrust line, where it should be.
