  • July 15, 2025, 11:20:07 PM
Author Topic: O.S. LA .40 for speed.  (Read 20755 times)
Re: O.S. LA .40 for speed.
« Reply #50 on: December 14, 2015, 11:47:49 AM »
I hope the little Kavan starter has enough omph!!
This is a "well, duh" thing if you've used starters before, but it came as a surprise to me when I first saw it.  And you're a CL guy, so maybe you've always averted your gaze when those newfangled starter thingies were taken out.
Turn the engine backwards against compression, then wield the starter -- by the time it gets on compression again it'll have a fair bit of momentum to carry it over, and the engine will spin (but maybe not start -- that depends on you).  It takes a lot less effort for the starter when you do that.
Offline john ohnimus
« Reply #51 on: December 14, 2015, 01:19:40 PM »
I've observed the technique on numerous occasions. Just a little leery hand starting those little sharp props!!!
Hard Tellin'....  Not Knowin'
AMA 413710
« Reply #52 on: December 14, 2015, 06:07:33 PM »
Wearing a nice thick glove will vastly increase your chances of having all the pieces to give to the surgeon.
« Reply #53 on: December 14, 2015, 06:10:09 PM »
I already have "26" reasons from a previous encounter with an APC to careful.
AMA 413710
