  • June 16, 2025, 02:50:49 AM
Author Topic: Alloy aluninum for  (Read 2840 times)
Alloy aluninum for
« on: July 27, 2017, 05:28:10 PM »
I am working on a project that requires aluminum beam engine mounts.
I see that McMaster Carr offers 6061 T6 in the size I need.  Is this an OK alloy for engine mounts?  It seems to be all they offer.
Offline Bob Heywood
Re: Alloy aluninum for
« Reply #1 on: July 27, 2017, 07:28:41 PM »
6061 T6 has been around since the mid- 1930's and is considered a versatile, general purpose alloy. It is easily worked. While not quite as strong as the 7075 alloy, you should have no problems.
"Clockwise Forever..."
« Reply #2 on: July 27, 2017, 07:34:48 PM »
There's a bunch of mail-order metal places that sell a wider variety of stuff for less money than McMaster.
6061-T6 should be fine, but I think that 2024 or the 7000-series stuff may be preferred by people who, like, actually know this stuff.
« Reply #3 on: July 28, 2017, 06:39:42 AM »
Thanks.  What is the better source?  I hope to find a cross section that works & just do the drilling.
Offline bill bischoff
« Reply #4 on: July 28, 2017, 08:12:37 AM »
Try onlinemetals.com.  1/4" x 1/2", 2024-T4 alloy. You can buy one foot for about $5.
« Reply #5 on: July 28, 2017, 08:35:09 AM »
Thanks.  Online looks like pretty-much what I want.
Offline pmackenzie
  • Pat MacKenzie
« Reply #6 on: July 28, 2017, 10:29:04 AM »
Forget about 6061-T6 it's soft and gummy to work with. Get some 2024-T3, T4 or T6.  If you need the best 7075-T651 is very hard and tough, machines like brass, good for making conrods, bellcranks and other critical components.
What do you need exactly, I probably have it.
6061 works great for motor mounts. I have made many,many sets from it for speed limit and no-one who has used them has ever had a problem.
I have used 7075 for my own F2D mounts, but have not noticed any difference in use between them and those made from 6061.
Pat MacKenzie
MAAC 8177
« Reply #7 on: July 28, 2017, 12:56:03 PM »
Thanks for the advice.
1/4" plate is only 6.35mm.  With a 3mm hole drilled it that only leaves 1.6mm on each side of the hole.  Is that enough?
I'm away from my shop today.  How thick are the mounts we use for FORA F2d's?
Offline C.T. Schaefer
« Reply #8 on: July 28, 2017, 05:17:01 PM »
I bolted my TZ to 1/8 aluminum plates. Snapped like a twig
« Reply #9 on: July 29, 2017, 08:00:17 AM »
TZ?
Offline Ken Burdick
« Reply #10 on: July 29, 2017, 10:32:26 AM »
thicker than that.......
« Reply #11 on: July 29, 2017, 01:10:57 PM »
Too many other variables, not least of which is the alloy.  Any time you give a definitive "yes" or "no" to a vague question you're pretty much guaranteeing that you'll be wrong for some circumstance.
Post a sketch of what you want to do?  With enough depth to the beam a hole like that might work, but it might not, and your motor mounts may die an early death of fatigue around the rear mount holes -- or not.
« Reply #12 on: July 31, 2017, 04:54:18 PM »
I  measured some engine mounts that worked OK and concluded that 1/4" is thick enough for a 15.
Thanks for the input.
« Reply #13 on: August 01, 2017, 06:26:11 AM »
OS  TZ .18 on a clown
