  • August 02, 2025, 07:25:29 AM
Author Topic: Are my lines legal for Sportsman Speed Stunt/  (Read 2977 times)
Offline Skip Chernoff
« on: June 09, 2017, 09:00:49 PM »
I'm getting ready for Brodaks and checked the line length on my Fox 35 Sportsman Stunt Speed entry. Center line of ship to centerline of handle measured 59' 4"...am I legal?
My plane was built from the remains of one of my crashed R/C Club 40 Pylon racers. Kinda looks like a Buster.  In practice flying ,my best was 25 sec for 7 laps. Found the APC 9x6 fastest for my plane. Take off RPM was 11.5k See you guys soon! PhillySkip
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: Are my lines legal for Sportsman Speed Stunt/
« Reply #1 on: June 09, 2017, 09:15:05 PM »
I have seen some CD's go +/- 6" on the length, but you also need to verify the line diameter
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline bob whitney
« Reply #2 on: June 09, 2017, 10:02:13 PM »
find a handle with 2 in longer leads I have a handle with some long leads u can use at Brodaks if u would like
rad racer
« Reply #3 on: June 10, 2017, 07:44:07 AM »
The lines are .015 ,so i'm 2" short ? Is it legit to make up like a 6" connector piece of line to go between the handle and the original lines? This would be an easy fix.
BTW thanks all for offering help . Hey does anyone have an extra Fox 35 head gasket I could buy? I blew one out while test flying....PhillySkip
Offline Bob Heywood
« Reply #4 on: June 10, 2017, 10:32:13 AM »
AMA Rules only permit two(2) connectors per line. I've seen some long clips to make up differences but nothing like 2".
5. Size, Construction and Measurement of Control Lines
Length, diameter, and types of lines permitted are stated under the specific rules for each event. The number and sizes of lines to be used, as specified for each event, are minimum requirements; they may be exceeded at the discretion of the contestant. However, if more and/or larger lines are used, no adjustment in the timing and/or judging procedures will be made to compensate for them. All lines used to control flights shall be steel wire or metal of equivalent strength, in good condition, and free from kinks and rust. Line connections to handle an aircraft must have a strength equal to or greater than that of the flying lines. No swivels are to be used as part of the control system of Control Line models. Control lines shall be of uniform diameter from the lead-out connections to the handle. No more than two (2) connectors may be used per line.
"Clockwise Forever..."
« Reply #5 on: June 10, 2017, 11:52:08 AM »
It's really easy to make up lines.  I suggest that for the future you throw $50 bucks in the general direction of MBS model supply and get 1000' of right-sized line for the events you fly, plus all the bits and bobs you need to make up lines.
Or, use the handle with the extra-long leadouts.
Or, ponder the fact that no one has said how long the connectors can be...
Online Fredvon4
  • Central Texas
« Reply #6 on: June 10, 2017, 12:03:03 PM »
Skip you head gasket request is bound to be lost in the din of the topic
I do not compete, period, but the "no more than 2 connectors~" does NOT make sense to me...I always need 4...two(2) at the flying line to lead out near the plane and two(2) at the flying line to handle connection....
Wait.!!..I read and re-read and it is "Per line"....OK relax....I fixed my own ignorance
Skip...Make really long connectors and you are good
Fred von Gortler IV
« Reply #7 on: June 10, 2017, 03:46:49 PM »
Save your self a head ache and order bulk lines from MBS Model Supply and make them correct length.  Now if you could get to the lead outs you could put longer lead outs in.
« Reply #8 on: June 10, 2017, 06:35:22 PM »
Guys I'm leaving for Brodak's in the morning. I'll bring a set of old 61' lines cut them to size and wrap the ends. Eventhough I'm flying a bunch of events ,there is still down time to fix a set of lines. Brodak's is a blast,wish me luck!.......PhillySkip
« Reply #9 on: June 10, 2017, 08:05:29 PM »
Best of luck!
