  • July 15, 2025, 10:36:46 PM
Author Topic: My second Perky  (Read 6179 times)
Online Paul Smith
My second Perky
« on: March 18, 2017, 02:11:01 PM »
I put together my first Perky in about three weeks and it lasted me 12, maybe 13 years.
I've broken ground on a replacement.
Second verse, pretty much like the first.
I use a wood pan type of construction.  The original has held together OK with three 4/40 bolts.  The new one will have two 3 mm bolts.  I've gone metric via Bob Hornberger (father of State Rep Pam) of Metrics Unlimited.
Step One is crudeing it in like a Viking ship.
Online Paul Smith
Re: My second Perky
« Reply #1 on: March 18, 2017, 02:12:33 PM »
Step Two is to go out the frozen barn and run it by the belt sander.
As you might notice, some old aluminum engine mounts have been buried to give the engine something to sit upon.
The Wheel weaves as The Wheel wills
And none can see the pattern until it is done.
The lives of men and the live of nations,,,
,,,oh well, you all know this.
« Last Edit: March 18, 2017, 04:23:11 PM by Paul Smith »
Online Motorman
Re: My second Perky
« Reply #2 on: March 18, 2017, 07:20:13 PM »
blank
« Last Edit: March 06, 2022, 09:03:35 AM by Motorman »
Re: My second Perky
« Reply #3 on: March 18, 2017, 08:02:32 PM »
Paul,
Nice planking.  ;D
CB
Online Paul Smith
Re: My second Perky
« Reply #4 on: March 19, 2017, 04:52:31 AM »
Big ribs?  Sure.
I layed up the wing from scrap wood and plan to sand it to shape on the belt sander, much as you would with one big piece if 1/2" balsa, but a little lighter and MUCH less expensive.
Since the ribs will be sanded down thin, I made them wide so as to hold the LE & TE together.  Also, I made them even thicker on the outboard side, since I'll be adding even more tip weight.
The other photo was the top of my first Perky during a rehab.  The principle will be the same on this model.
Offline C.T. Schaefer
Re: My second Perky
« Reply #5 on: March 19, 2017, 07:21:39 AM »
Lookin' good Paul!  There are a couple new ones taking shape in N.J. too.
Offline bob whitney
Re: My second Perky
« Reply #6 on: March 19, 2017, 12:10:42 PM »
Florida also y1
rad racer
Re: My second Perky
« Reply #7 on: March 19, 2017, 02:58:01 PM »
Why not leave out board solid and save tip weight?   I need to start on my Perky if I can find where I misplaced them.  Have a Cox that should work.
Online Paul Smith
Re: My second Perky
« Reply #8 on: March 19, 2017, 06:00:01 PM »
That's a thought.  I did go somewhat heavier on the outboard.  But lead nearer the tip has more leverage that wood near the body.
It only has 9" of wing on each side.  With the pointy tips, you can't get the weight much more than 8" out, so it takes a fair bit to keep it from torquing in.
The leadout guide has a similar issue.  You can only get it about 8" inside the CL and it needs to be ahead of the LE for best results.
Offline Lyle Spiegel
Re: My second Perky
« Reply #9 on: March 19, 2017, 06:03:10 PM »
I assume the new Perkys are scratch built, or does Blackhawk new owner still offer kits?
Lyle Spiegel AMA 19775
Online Paul Smith
Re: My second Perky
« Reply #10 on: March 19, 2017, 07:31:48 PM »
Mine are built from plans.
The Black Hawk Perky was rather popular.  You might find one on the aftermarket.
Here is the plan.
With an 18" wingspan as a  guide you can get it printed to size.
There's a lot left to the imagination, including the bellcrank & leadouts.
People respected Jim Walker's lawyers.
Online Paul Smith
Re: My second Perky
« Reply #11 on: March 22, 2017, 05:02:57 PM »
Let me think about this step-by-step:
1. Chose the engine.
2. Bottom
3. Landing gear.
4. Wing
5. Top
6. Tailplane.
7. Flight controls.
8. Fuel tank.
9. Final assembly
10. Paint
11. FLY
Online Paul Smith
Re: My second Perky
« Reply #12 on: March 22, 2017, 05:05:40 PM »
After a few passes of the sander...
Online Paul Smith
Re: My second Perky
« Reply #13 on: March 23, 2017, 07:40:25 PM »
Some of the rough edges smoothed-out and carbon veil applied.
Offline bill bischoff
Re: My second Perky
« Reply #14 on: March 27, 2017, 06:17:28 AM »
Aren't the wide ribs on the inboard side?
Online Paul Smith
Re: My second Perky
« Reply #15 on: March 27, 2017, 08:17:00 AM »
Huh?   Maybe I test-fit it backwards.
Online Paul Smith
Re: My second Perky
« Reply #16 on: April 01, 2017, 05:37:13 PM »
Perky progress has bogged to a snail's pace.  My local Macomb County defense suppliers are bogged-down with Muslim War contracts.  It has became tough for a Perky-speeder to get work done with magnesium, titanium, carbon fibre, secret micro-fibers and essential precision-machined sub-assemblies.  Nevertheless, I will still endeavor to get something together in time for The Brodak.
B-J Machining, the source of my spinner adapter, was pre-occupied with a special run of A-10 armour-piercering ammunition.
Bob Hornberger of Metrics Unlimited was pre-occupied with election of has daughter, Pamela, to our State Legislator.
Modeling is above politics, but not much above.
Re: My second Perky
« Reply #17 on: April 02, 2017, 05:43:26 AM »
Looks like she's almost ready to go!
Offline Ken Burdick
Re: My second Perky
« Reply #18 on: April 02, 2017, 07:57:57 AM »
and I thought I had trouble getting a 4mm pressure tap for my D engine...........
Looks good Paul.
K
Online Paul Smith
Re: My second Perky
« Reply #19 on: April 12, 2017, 02:23:41 PM »
Springtime in Michigan means moving the paint shop to the barn.
Not everybody loves the smell of butyrate in the morning.
Re: My second Perky
« Reply #20 on: May 07, 2017, 06:50:16 AM »
How does BH Phantom compare to Perky? From pics it looks about same.
Online Paul Smith
Re: My second Perky
« Reply #21 on: May 07, 2017, 08:17:40 AM »
Pretty close, but it's not exactly a Perky.  It would probably be a fair contest, but deal is a deal.
I noticed that an RC on line shop was offering Phantoms at a discount price & I tried to order a couple on Day One.  Sold out already !!
