  • July 31, 2025, 08:23:05 AM
Author Topic: Monoline termination  (Read 1925 times)
Offline Ron Blombery
« on: March 09, 2022, 09:48:40 PM »
What is the best way to terminate monoline wire at the twist unit end?  The fitting is a steel cylinder with a slot that the wire can slide into (see photo)
Thanks for your help
Ron
Offline Mark wood
Re: Monoline termination
« Reply #1 on: March 10, 2022, 06:30:13 AM »
For flying small light models use the AMA method as can be found in the General section. For heavier models like D or Jet, it is a good idea to add a hook for the loop to connect with.
Life is good AMA 1488
« Reply #2 on: March 10, 2022, 07:25:12 PM »
Got it!  Thanks very much.
Ron
Tags: monoline
