  • July 31, 2025, 08:19:25 AM
Author Topic: Marking a Speed circle  (Read 22188 times)
Offline BillLee
« on: December 06, 2023, 02:22:51 PM »
Assume you have a nice, new patch of asphalt for flying our speed events. The asphalt is new, there are no markings on it.
I have already installed a pylon mount.
Keep in mind that this will not be used for any other use, just to fly speed. But ALL KINDS of Speed!
The question for you: what circles should we paint on the asphalt?
Thanks.
Bill Lee
AMA 20018
Offline BillLee
Re: Marking a Speed circle
« Reply #1 on: December 06, 2023, 02:34:50 PM »
Information:
The FAI rules specify a circle at 3 meters and another at 21 meters. This roughly correspond to a 10' radius and 69' radius.
I do not believe there are any specifications for AMA Speed events.
Bill Lee
AMA 20018
Online Carl Cisneros
« Reply #2 on: December 06, 2023, 05:49:26 PM »
you can round the 69' to 70' (for US events), and also
with the B,Dand Jets, make one painted circle out to 80' radious as well.
Their min. line length in AMA is 70'.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Online Motorman
« Reply #3 on: February 18, 2024, 06:21:54 PM »
Just paint one big 80' radius safety circle, no real need for anything else.
Offline Mike Hazel
« Reply #4 on: February 19, 2024, 09:16:46 AM »
Yup,  80 foot radius safety circle is what we do in these parts.
« Reply #5 on: February 19, 2024, 10:52:35 AM »
  I would look into the paint used for this. On the square pad at Buder, we had a big circle painted at the max perimeter, and another about 10ft diameter at the center with a 1ft dot in the middle. the dot got slippery in wet weather. And oddly enough, the asphalt cracked right along side the painted surfaces. Circles were about 3 or 4 inches wide and I think we had that done by a company that did parking lot and tennis court striping. The cracks were pretty serious in size. After the last resurfacing I think we changed up on that but don't remember the details. No center dot but some one did paint the 10ft and out diameter circles again and they are also cracking. I would consider dashed line spaced apart maybe. or look into specific paints. I remember we once marked our circles on a temporary site with dry wall strips for a contest. The highway department here uses some sort of tape for temporary lane changes for construction, and that may work out better. If good money was spent for the paving, no need to do anything that causes cracks, because that is the beginning of bigger problems over time.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #6 on: March 10, 2024, 09:42:53 AM »
one of the paved circles at Buder Park that is used for general flying has the 75 foot radius / 150 diameter circle painted on it which clearly marks do not go inside of this line if a model is flying. I agree with the 80 foot radius line on the speed circle for the same reason
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
