  • July 14, 2025, 02:03:45 AM
Author Topic: Latest & most current Perky & Fox 35 Speed Rules  (Read 3944 times)
« on: September 28, 2017, 11:29:28 AM »
Does anybody have any authoritative knowledge of any changes to Perky or Fox 35 Speed rules since this June?
I plan to submit my events to Brodak soon.
Offline C.T. Schaefer
Re: Latest & most current Perky & Fox 35 Speed Rules
« Reply #1 on: September 28, 2017, 03:27:49 PM »
I'm pretty sure the current rules are stable.   TS
« Reply #2 on: September 28, 2017, 04:15:27 PM »
I hope so.  I just want to know of any surprises before it's too late.
I'll even pop for a gallon of funny fuel for Fox 35 Speed.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #3 on: October 08, 2017, 07:21:38 PM »
There haven't been any changes to the Fox 35 rules as defined by the Lafayette Esquadrille since Feb 2017. John adjusted the pull test but that is minor and that was in Feb 2017. There has been no reason to change the rules since that time. We define the fuel as 5% but if you want to use 10% just put that on the sanction and state that you are using Lafayette Esquadrille rules but will use the 10% fuel instead.
Fred
https://lafayetteesquadrillecl.files.wordpress.com/2017/02/fox-35-rules-feb-2017.pdf
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Lyle Spiegel
« Reply #4 on: October 27, 2017, 02:58:13 PM »
rather than disallowing ABC / AAC  , consider a sub class.  At checkin, the pilot can  designate if engine is steel liner or other. The entries with ABC/ ACC setup can have their own placing. This way all Perky 's get to enter.
Lyle Spiegel AMA 19775
« Reply #5 on: October 27, 2017, 03:13:14 PM »
I'm not looking to change the rules.  I just want know if rules will be the same for next years Brodak Fly In.  At this point it seems safe to say 2018 with be the same as 2017, for Perky & Fox 35 Stunt.
Perky continues to grow in both speed & participation.
I think Fox 35 has just about come to the end of the line.  The question of how much you can trick up something you call a Fox 35 Stunt has been answered.
« Last Edit: October 29, 2017, 06:21:40 PM by Paul Smith »
« Reply #6 on: October 29, 2017, 01:07:31 PM »
The Fox 35 Rules are stable and are not changing, late last year the rules were clarified so that you couldn't use a rear intake / needle valve setup. If the engine looks like a Fox 35 Stunt we don't get all twisted about what liner, head or needle valve is being used. If the person modified the timing that is also hard to inspect at the flying site. The only inspection we do here in St Louis is a 5 second look to make sure it's not using pressure, it has a front intake with needle valve and that it's a Fox 35 Stunt engine
The only thing to separate out the slower and fast airplanes is to have two classes, Beginner and Expert. Once you fly faster than let's say 80 mph you are flying in the Expert Category. I would agree that the mods to the Fox 35 Stunt are well understood, there is still plenty of life left in the Fox 35 Stunt Speed event. I would propose that you have two average speed awards - one for Perky and another for Fox 35 Speed. the average is really what you are trying for!
Having the Average trophy was part of the original Perky event so I don't understand why it's not offered at the Brodak contest. That way people with slower models can shot for the Average award. I certainly do not try for the top speed.
Fred
« Last Edit: October 31, 2017, 03:53:36 PM by Fred Cronenwett »
Fred Cronenwett
« Reply #7 on: October 29, 2017, 06:24:47 PM »
I'm leaning toward just the usual three places in Fox 35 and Perky.  These events are now all-out professional speed and nobody wants to be average.
I will request three places plus an average award in the Sportsman Class.
Offline bob whitney
« Reply #8 on: November 06, 2017, 08:46:13 AM »
question  in the sport fox 35 class seeing as inverted and upright flight is needed dose the person entering have to fly the plane
rad racer
Offline Carl Cisneros
« Reply #9 on: November 08, 2017, 10:41:00 PM »
Great question Bob.
Have planted my r-master a few times trying to learn to fly inverted.   :'(
carl
p.s.  do you have a couple prop adapters for teh Cox Conquest 15 I can get from you for teh props I got at Brodaks from you?
Carl R Cisneros, Dist IV
Control Line RB
« Reply #10 on: November 09, 2017, 07:47:38 AM »
As in most Speed events, the contestant may employ a pilot.  To be fair about, the named entry needs to a least take part in the starting and adjustment.
