  • August 01, 2025, 05:47:53 AM
Author Topic: Proto Vee Tail  (Read 3661 times)
Proto Vee Tail
« on: April 14, 2021, 11:38:55 AM »
blank
« Last Edit: August 17, 2021, 08:48:58 PM by Motorman »
Re: Proto Vee Tail
« Reply #1 on: April 14, 2021, 02:31:37 PM »
Vee Tail with one elevator, which side do you put the elevator. Inboard elevator, up acts like right rudder but pushes inboard side down. Outboard elevator, up is like left rudder but holds outboard wing down. Which effect is dominate?
Motorman 8)
If this is for PA then which side is dominate is nearly moot.  Both of them will suck.   We go to great lengths to make sure our controls don't produce roll or yaw and this will put you up to your eyeballs in both.
But you did ask......., would opt for the inboard since there are more inside corners in the pattern than outside and the prop induced airflow over the wing will be on the outboard side (assuming CW rotation).
Speed does this all the time but they don't do hourglasses either.  I have lost one of my elevator servo's on an RC Sailplane V Tail and had to land it with only one side working.  It wasn't difficult but we don't have ailerons.
Oops - I didn't notice the forum when I replied - Never Mind.
« Last Edit: April 16, 2021, 10:32:28 AM by Ken Culbertson »
Offline Bob Heywood
Re: Proto Vee Tail
« Reply #2 on: April 15, 2021, 06:47:26 AM »
Motorman 8)
For Speed planes you are mainly trimming for level flight. Control input is minimal. It does not matter which side is used. I've done both.
Plus, our V-Tails are not really like a Bonanza or Swee Pea. My Swee Pea had one rudder-vator on the outboard side. No issues.
Unless you are thinking of doing one with that much of a V angle.
"Clockwise Forever..."
Re: Proto Vee Tail
« Reply #3 on: April 15, 2021, 11:48:38 AM »
Apart from the control issues mentioned, the prime disadvantage I see is the loss of structural continuity from side to side which would dictate the the need for heavier construction.
Offline Bob Heywood
Re: Proto Vee Tail
« Reply #4 on: April 16, 2021, 08:36:47 PM »
Bob, Cool plane, looks like a Tornado 7-6 is that a SuperTigre 15 on there? What is the angle of your tail?
Motorman 8)
Yes, the engine was an ST G15 with a Tornado 7 x 6.
The V angle was roughly 25 deg from horizontal.
It was a very fast airplane.
Re: Proto Vee Tail
« Reply #5 on: April 20, 2021, 12:04:57 PM »
"was"  ????
Offline Bob Heywood
Re: Proto Vee Tail
« Reply #6 on: April 20, 2021, 03:08:55 PM »
"was"  ????
The plane was active circa 1970+. It had one standout season. After a full season of racing the outboard wing parted company during a pit stop at the King Orange. By then the Rossi was beginning to be tamed and The G15 headed out to pasture.
