  • June 24, 2025, 03:56:49 AM
Author Topic: Torquette  (Read 3432 times)
Offline Dennis Saydak
Torquette
« on: March 04, 2015, 04:18:47 PM »
A building buddy of mine and I decided to build a couple of Torquettes for fun in-between working on other major projects. We have a pair of reverse rotation Tee Dees for them. It's a cute design. Here's mine so far.
Offline Fred Quedenfeld jr
Re: Torquette
« Reply #1 on: March 06, 2015, 04:09:29 PM »
Is it a kit or scratch built
where can one get the kit or the plans
are you going to use a button belcrank
Fred Q
Offline eric david conley
Re: Torquette
« Reply #2 on: March 06, 2015, 07:12:02 PM »
What does this have to do with speed. Wouldn't this fit the 1/2A subject much better?  Eric
Eric
Re: Torquette
« Reply #3 on: March 07, 2015, 10:00:06 AM »
I believe it was designed for 1/2A Proto speed by the late and great Dale Kirn.
Re: Torquette
« Reply #4 on: March 07, 2015, 11:18:12 AM »
John, you are correct. That's why I posted in this section. I believe The Knights of The Round Circle Club in California still fly a Torquette speed event in honor of Mr. Kirn.
Fred, to my knowledge Torquette was never kitted. It's a pretty straightforward scratch build, except for the aluminum fuselage doubler. Fortunately I know someone with a metal shear, which made cutting out our doublers easy. I'll use a standard bellcrank with small Brodak lead-out connectors. This is really a sport /speed model for us.
The construction article and plan is available here:
http://www.kotrc.org/events/torquette.pdf
« Last Edit: March 07, 2015, 03:22:32 PM by Dennis Saydak »
Re: Torquette
« Reply #5 on: March 07, 2015, 12:01:55 PM »
     Thanks guy's I didn't know that. Eric
Eric
Offline Phil Krankowski
Re: Torquette
« Reply #6 on: March 07, 2015, 08:21:26 PM »
That aluminum doubler could be cut very easily (but not very quickly) using a coping saw and a bench pin (basically a 1x4 sticking off the bench with a fork shape sawn into the end)
Looks like a bit of fun.
Phil
Offline HowieCuda
Re: Torquette
« Reply #7 on: October 12, 2015, 04:52:08 PM »
The KOTRC in conjunction with the C/L Speed flyers of SoCal hold Muciano Hollow Log and Torquette Proto speed at the December Toys For Tots meet.
I fly my CS, with a LH crank, powered Torquette in 1/2 A Proto occasionally and have posted better than 90 mph on the contest 10% fuel.
Most of the guys that have used standard RH rotation have crashed. The alternative is to fly clockwise with a RH crank.
Howie
