  • August 01, 2025, 08:15:40 PM
Author Topic: Harters 40 Pan  (Read 1619 times)
Online Motorman
Harters 40 Pan
« on: June 02, 2020, 07:07:15 PM »
blank
« Last Edit: August 22, 2021, 07:50:27 AM by Motorman »
Offline Dennis Saydak
Re: Harters 40 Pan
« Reply #1 on: July 13, 2020, 05:46:17 PM »
I have two of them. One is drilled for an unknown engine, the other is undrilled. Other than that they are close to being identical. except one is slightly longer than the other. PM me if interested. I can take pictures.
Re: Harters 40 Pan
« Reply #2 on: July 18, 2020, 03:51:44 PM »
1.237".
There seems to be two versions of this pan. The early one has squared off motor mounts and wing pad. The later one is rounded off with more beef in this area. It also has two little nubs on the back of the motor mounts with dimples that match the spread on a Fox 35 stunt.
Dennis, can you measure the spread between the motor mounts on your longer pan.
Motorman 8)
Offline John Given
Re: Harters 40 Pan
« Reply #3 on: July 29, 2020, 04:53:52 AM »
PM sent
