  • June 28, 2025, 08:42:27 PM
Author Topic: TRANSFER  (Read 10358 times)
Offline RC Storick
TRANSFER
« on: August 13, 2006, 09:53:13 PM »
     What is this?
I stumbled upon this pic a while ago. I like the looks of it. BUT, I hate to ask, which end is forward? I would imagine the prop is in front, but I see no lead outs, and the stab sticking way out like that is really confusing. So give a new guy a break and help me understand what I am looking at.
Thanks man,
Greg
 Report to moderator    206.148.228.132 (?)
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
Willis Swindell
Lieutenant
[applaud] [smite]
 Offline
Welcome to the Stunt Hanger.
     Re: What is this?
« Reply #1 on: July 29, 2006, 12:14:42 PM »
Looks like a pusher to me.
Willis
 Report to moderator    72.82.88.2 (?)
Willis Swindell
bill marvel
New Pilot
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #2 on: July 29, 2006, 04:56:31 PM »
Hi, Greg
I am not a speed person but I have seen variations of this configuration at contests.  It is a single wing tractor, not pusher.  If you look at the head, the engine is mounted on its side and if you follow the lines, there is a small, narrow fuselage without an elevator or rudder.  Speed planes in this class do not reuire much rudder.  The canard style of elevator is forward of the prop.  The engine exhausts to the rear.  That is a pipe that looks like a double fuselage.  It wouldn't likely exhaust to the front of the plane.  You can't see the tip of the wing but that is where the leadout(s) would exit.  Speed planes of this type often use monoline instead of the conventional two lines.  Unless the aircraft is lying on its back or the photograph was accidentally "flopped", it would appear that the plane flies clockwise.
These are serious speed planes and can haul.
Thanks for the interesting picture.
 Report to moderator    24.107.75.234 (?)
Willis Swindell
Lieutenant
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #3 on: July 29, 2006, 06:48:29 PM »
Still think it's a pusher, look closely at the the stab I think I see a elevator and the prop is on backwards. and the tank vent is facing the same way the pipe is.
Willis
« Last Edit: July 29, 2006, 09:33:33 PM by Willis Swindell »  Report to moderator    71.241.31.86 (?)
Willis Swindell
bill marvel
New Pilot
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #4 on: July 29, 2006, 08:24:09 PM »
By golly, I think you are right, Willis.  I had noticed that elevator, too, but didn't think enough about it.  I missed the prop completely.  Good job.
Greg!
Willis and I think it is a pusher!!!
Grins,
Willis Swindell
Lieutenant
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #5 on: July 29, 2006, 09:28:58 PM »
Joey you fly these side winders what do you think?
Willis
 Report to moderator    71.241.20.248 (?)
Willis Swindell
Joey Mathison 9806
Moderator
Lieutenant
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #6 on: July 29, 2006, 10:41:23 PM »
pusher and it takes out the prop on take off.
 Report to moderator    207.200.116.13 (?)
200 mph man ama#9806 joey mathison
Ironbomb
ACE
Commander
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #7 on: July 30, 2006, 12:35:13 PM »
A  pusher!!???   well, the "exhaust" looking pipe really thru me. Must be some high zoot setup. I saw the short flim of the British guy breaking the world record. Could his plane be like this one? It also looks like a single blade prop too. Must be fun to balance those.
Thanks for the input gents
Greg
 Report to moderator    206.148.228.43 (?)
Greg Bossio
AMA 834382
Joey Mathison 9806
Moderator
Lieutenant
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #8 on: July 30, 2006, 01:58:42 PM »
the record holder that you speak of is not a pusher. the one blade props are easer to work on only one blade to file the balance is done with a counter balance inside the spinner if you need more weight you just solider some on file to take off. so pictures are at http://community.webshots.com/user/mathison205
supertiga
New Pilot
[applaud] [smite]
 Offline
     Re: What is this?
« Reply #9 on: August 10, 2006, 03:24:33 PM »
its a pusher
pusher prop
elevator at rear of stab
exaust looking opening in side of cower is intake for air intake? cooling?--outlet must be small hole at bottom of cowel?
exaust pointed wrong way?
i duno
 Report to moderator    216.79.211.66 (?)
Erin Roland
Offline dynasoar1948
Re: TRANSFER
« Reply #1 on: August 13, 2006, 10:49:33 PM »
Honest, guys this is a pusher F2A airplane from Britain.  It has not flown yet (so far as I know) due to takeoff dolly problems.
There are advantages to running the prop in the accelerated boundary layer around the fuselage and not having a fuselage and cowl in the slipstream.  Thete should be a thimble arouns the exhaust stinger to turn the exhaust around to the rear.
Dynasoar
William Stewart
Offline W.D. Roland
Re: TRANSFER
« Reply #2 on: August 16, 2006, 10:17:29 PM »
no fair!
the exaust turner arounder thingie aint in de picture **)
David Roland
51336
