Speed,Combat,Scale,Racing => Speed Talk => Topic started by: Motorman on November 12, 2019, 03:42:53 PM
blank
OK. The hole is .270-.280. Fox stunt spraybar works pretty good. However, our best stuff uses K&B style needle with a jet on the other side. Much thought and R&D on the gas tanks though. Usually we get off clean but not like a pressure system or bladder. TS
We plan to be there. Trying not to freeze fingers!
Update. Did some more work on a .35 for one of our guys. It was running real good on the bench when the crank liberated itself and on the way past took a nice slice on my knuckle. This was the standard .35 crank with a modified Gardner. The .35 one with his altered timing. I guess if Henry can toss cranks then why not us 'regular' guys ;D. TS
