  • August 02, 2025, 04:32:45 AM
Author Topic: Fox Speed Reference  (Read 3833 times)
Offline Dave Edwards
Fox Speed Reference
« on: November 20, 2016, 04:47:50 PM »
Got my fox speed in the air and completed the mile from a standing start at the last Middlesex event - right about 87mph.  For the guys doing all the cool engine work, use this as a reference: box stock engine, 29%caster, 10%nitro fuel, 8x8apc prop, 5-10mph wind.
If I play with props and get a perfect run on a calm, cool day, probably good for 90+mph.
Re: Fox Speed Reference
« Reply #1 on: November 20, 2016, 08:10:47 PM »
What kind of airplane, profile Q rat or full blown pan job?
« Reply #2 on: November 21, 2016, 03:17:53 PM »
Plane was made up specifically for fox race from the scraps lying around the shop..  Kind of a cross between a f2c from the 70s and a tqr.  Solid wing, full fuselage, pretty good aerodynamics, a bit heavy but flies great.
Offline Al Ferraro
« Reply #3 on: November 22, 2016, 08:26:54 AM »
Dave's Fox Speed
« Reply #4 on: November 23, 2016, 02:13:10 PM »
So, just out of curiosity, has any one broken the 90mph mark (one mile from a standing start) with a stock Fox 35?  If so, what combination of props/fuel/planes did you use? Likely someone has a sleek fox racer that can do this.
The fastest modified fox 35 I have seen is 107mph, roughly a 20% improvement in speed.  If my math is correct (power goes as V^3) that means a 75% boost in power is required.
« Reply #5 on: November 24, 2016, 10:22:07 AM »
87 MPH is the  best I've heard for stock engine.
I did 69 at The Brodak with a stock engine and a sport-type airplane.  I doubt that the airframe made up the whole 18 MPH.  Maybe the solidness of the pan made the engine run better.
