  • July 30, 2025, 11:29:24 AM
Author Topic: Fox Speed Block  (Read 6549 times)
Offline BillLee
Bill Lee
AMA 20018
Re: Fox Speed Block
« Reply #2 on: July 02, 2023, 11:22:08 PM »
Ok, I'll bite...and maybe learn something. WHY is this the preferred case for what I assume is a "no modification limit rule" event, correct? It is pre-muffler lugs, but why does that matter? Or is there something inside that is perceived as better?
Re: Fox Speed Block
« Reply #3 on: July 03, 2023, 07:40:37 AM »
In reality, there is no rule that limits modification of engines in Fox 35 Stunt Speed.  It's wide open to machinists to make and use whatever they can.
Like most older modelers, I have large stash of Fox 35 Stunts that I have run hard and no longer give contest performance.  I don't need few fifties enough to try to pass them off to suckers on Ebay.
Offline bob whitney
Re: Fox Speed Block
« Reply #4 on: July 03, 2023, 09:22:24 AM »
NOT TRUE, u band my R/V version at Brodaks RAD S?P
rad racer
Re: Fox Speed Block
« Reply #5 on: July 03, 2023, 06:10:02 PM »
My Fox 4011 got bann too but only for displacement. Hey Bob we were really out there with the mods weren't we.
That case is the good one because it has the head bolt bosses, the wart bypass (biggest) and the heavy exhaust bridge.
Re: Fox Speed Block
« Reply #6 on: July 05, 2023, 05:35:59 PM »
Got it. Thanks Motors....
