  • August 01, 2025, 05:33:38 AM
Author Topic: Fox Speed  (Read 1889 times)
Fox Speed
« on: November 12, 2019, 03:42:53 PM »
blank
« Last Edit: August 28, 2021, 06:42:44 PM by Motorman »
Offline C.T. Schaefer
Re: Fox Speed
« Reply #1 on: November 13, 2019, 05:07:34 AM »
OK.  The hole is .270-.280. Fox stunt spraybar works pretty good.  However, our best stuff uses K&B style needle with a jet on the other side. Much thought and R&D on the gas tanks though. Usually we get off clean but not like a pressure system or bladder.   TS
Re: Fox Speed
« Reply #2 on: November 14, 2019, 05:33:36 AM »
We plan to be there. Trying not to freeze fingers!
Re: Fox Speed
« Reply #3 on: November 14, 2019, 07:34:29 PM »
Update.   Did some more work on a .35 for one of our guys.  It was running real good on the bench when the crank liberated itself and on the way past took a nice slice on my knuckle. This was the standard .35 crank with a modified Gardner.  The .35 one with his altered timing. I guess if Henry can toss cranks then why not us 'regular' guys ;D.   TS
