  • July 15, 2025, 05:22:42 AM
Author Topic: Formula 40 Speed at Rouge Park, May 17, 2009  (Read 1346 times)
« on: May 19, 2009, 12:48:40 PM »
I got the club to include this event so I could try to fly my old Rat/Formula 40 plane that's been hanging on the garage walls since 1982.  The plane was built in 1970, first flown in 1973, and last competed in teh 1982 MAAC Nats. I invited some others to give it a go, but I was the only one that showed.
I gave the model about an hour of rehab last week and, with the help of Ken Towers, got it back in the air without much trouble. Just one short test hop to get a needle and then an official run of 14 laps, one mile from a standing start, in 29 seconds, 124.1 MPH
This was an all-time best F-40 run for me and my model, but not a serious threat to the record of 164.09 held by Mark & Montagino.
I attracted some interest from the others present and explained that's simple; all you need is a high-powered engine up .4028 and a landing gear.  No doubt there are plenty of rats that could be dusted off, as well as 40's and 36's left over from Rat, Combat, Class I Carrier, and RC Pylon.  You don't absolutely need pan job.  A Quicky or Outlaw Rat would suffice.
September 12, 2009.
124.1 MPH.
I plan to better it.
Can you?
Bring it!
Offline Joey Mathison 9806
Re: Formula 40 Speed at Rouge Park, May 17, 2009
« Reply #1 on: May 19, 2009, 03:43:53 PM »
 #^ #^ #^ #^ #^ #^ looks like you had a good time . thank you for posting the results y1
200 mph man ama#9806 joey mathison
Offline PaulGibeault
« Reply #2 on: June 08, 2009, 04:27:19 PM »
Paul,
I sucessfully used 32 oz. Rats for years before I went to dedicated lightweight F-40 models.
I think your model is capable of another ~ 8 MPH.
The external line connectors/connections cost you 2-3 MPH
Placing a wood fairing behind your LG & using a smaller wheel will help.
Placing a ~ 1/8" balsa on top of the pressure cowl exposing ONLY the cooling fins & not the rest of the head will help
Try using a 7-3/8 - 7.5 Dia X 7" Pitch prop (old Kelly if you have one is perfect)
Use a spinner.
Use a smaller (1 oz) tank or small pen bladder.....
Use a 2" handle line spacing
Find a 'tight' fitting head & reduce your head clearance to .004" if possible.....
LOTS of little things!
Have FUN
(NW Regionals 2009 F-40 winner using a K&B 6.5)
« Reply #3 on: June 09, 2009, 01:56:01 PM »
Thanks for the advice, but I won't be trying to squeeze another 6 MPH out of this airplane.
It's powered by a 1970 Series K&B 40, so Step One is a serious attempt to approach 165 MPH would be a whole new engine and airplane.
I set the first Formula 40 AMA speed record with this airplane in 1976.  It went 118 then and after a 33-year layoff made a new personal best.  That was pretty much the object of the exercise.
As an aside, back in 1973, it did 150 MPH flat out (not accel) with a Big Art prepared K&B Series 70 engine, but blew the engine on the second flight.  The used engine that I got to replace it never went over 130.  The first engine probably had one of those crooked crankpins that Art later discovered, but too late help me.
« Reply #4 on: June 09, 2009, 06:18:45 PM »
Paul what are the chances that you guys include speed in some more of your contest's. another fun speed event is one i saw at the north/west regionals it is about like the 1/2 a proto profile event only you must use a combat 15 with a muffler. they call the event f2d proto.
« Reply #5 on: June 11, 2009, 11:09:11 AM »
Hey Joey,
Sure was nice to see you at the Regionals. Unfortunately I live in western Canada
where (sadly) there is NO speed flying anymore. A note to Mike Hazel who's the
Pacific NW leading speed contact, might give you the info you request.
Certainly, the new F2D proto event is well attended & gathering interest
(something like a 1/2A proto on steroids....)
While at a Regionals dinner (assisted by strong drink) a "new" type of speed event
was invented by the BBB. ALL speed model types can compete equally against each other.
Stay tuned for more info....
Cheers, Paul  (aka Mr. Steady Forty)
