  • July 17, 2025, 01:12:32 PM
Author Topic: F-35 speed  (Read 3497 times)
Offline bob whitney
F-35 speed
« on: February 09, 2016, 03:44:05 PM »
  can anyone tell me what  Good RPM is for F35 Speed Engine and what Prop
rad racer
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: F-35 speed
« Reply #1 on: February 09, 2016, 09:32:32 PM »
We have been flying with a 9-6 prop here in St Louis, but I don't know what RPM we are getting.
Bob - We will be flying Fox 35 speed here in St Louis on Feb 28th (ICE-O_Lated Stunt and Speed) if you want to get some official flights in before the Brodak contest. It might be a little bit cold however here in St Louis in Feb, we will be lucky if the temps are in the 40's!
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline C.T. Schaefer
Re: F-35 speed
« Reply #2 on: February 10, 2016, 07:05:28 AM »
Hey Bob, We use the APC 8x8 as a standard. RPM    14.5  is decent on std 10/25 fuel.
Offline bob whitney
Re: F-35 speed
« Reply #3 on: February 10, 2016, 12:23:02 PM »
  thanks, i am up to 15000 on a rev-up 8/6
rad racer
Offline bob whitney
Re: F-35 speed
« Reply #4 on: February 10, 2016, 12:24:20 PM »
  i think it will fit into my Q-rat for some in air testing
rad racer
Re: F-35 speed
« Reply #5 on: February 13, 2016, 02:18:00 PM »
Geez Bob, At least you can do some testing. We are in the ice box up here. Just fussing in the basement but even that is too cold today!
Offline bob whitney
Re: F-35 speed
« Reply #6 on: February 13, 2016, 03:25:20 PM »
was out with the Free Flight guys today running some engines, 70 deg ,lite wind ,unfortunately no pavement to fly on
« Last Edit: February 13, 2016, 03:48:07 PM by bob whitney »
rad racer
Re: F-35 speed
« Reply #7 on: February 14, 2016, 08:05:13 PM »
If the weather cooperates I will be testing next weekend here in St Louis, the temps should be high 50's
We are getting ready for the ICE-O-Lated on the 28th
Fred
Fred Cronenwett
Offline Ken Burdick
Re: F-35 speed
« Reply #8 on: February 15, 2016, 09:40:49 AM »
Since I went against the grain and moved North to B.C. I have the same no pavement problem. I test 15-35 size speed projects on an F2D combat wing, alum mounts, launching stooge. It gives a pretty good indication of flight speeds and making changes to the engine.
K
