  • July 11, 2025, 11:30:07 PM
Author Topic: PERKY POSTAL CONTEST  (Read 978 times)
Offline LARRY RICE
« on: May 21, 2011, 12:58:16 PM »
      With June a week and a half away it is time to think about the Perky Postal Contest ... entries must be in by the end of June or first of July.  If you have not built a Perky yet it may be to late now as these are not quick build kits.
     GOOD LUCK TO ALL OF THOSE WHO ENTER!!!!
Larry
Offline LARRY RICE
Re: PERKY POSTAL CONTEST
« Reply #1 on: May 24, 2011, 09:12:44 AM »
The first times have arrived,   July is closing in!
Good Luck to all
Larry
« Reply #2 on: May 27, 2011, 10:56:08 AM »
Need to find mine under the dust and make a set of lines.   H^^
« Reply #3 on: May 28, 2011, 06:20:30 AM »
Could you please clarify?
Do you want just one score per person, or all you can get?
At Brodak's you can fly three times and have all three scores averaged into the mix.  Then each of your scores has a chance of winning.
Bottom line: I already submitted the results of one contest.  Should I bother to submit more?
Offline LARRY RICE
« Reply #4 on: May 28, 2011, 09:03:00 AM »
       Each contestant may submit 3 scores for the year.  If you want to pick other scores than the ones that you have sent in I will accept the new ones.  I am sure that you understand that the number of scores must have a limit and 3 is that limit.
Larry
