CLICK HERE--><--CLICK HERE
E PERKY KIT
Started by bob whitney, May 02, 2026, 12:44:06 PM
Previous topic - Next topic
Ernie evon, Dave Rigotti and 5 Guests are viewing this topic.
bob whitney
received my E PERKY kit in the mail today,it is well done with everything you need .mine came with a nass renewal form but no assembly instructions .i am sure this is an over sight .cant wait to get started on mine. maybe i can test it at Brodaks
  with CA it should be a one night build.
Like Like x 1 View List
rad racer
Dennis Toth
Bob,
How's the E-Perky coming? How are you going to finish it? Seems like a good candidate for MonoKote. Post some pictures.
Best,   DennisT
Dave Rigotti
Not an oversight. Latest BOM, Build instructions, and photos are available for download at clspeed.org
Enjoy the build....
Quote from: bob whitney on May 02, 2026, 12:44:06 PMreceived my E PERKY kit in the mail today,it is well done with everything you need .mine came with a nass renewal form but no assembly instructions .i am sure this is an over sight .cant wait to get started on mine. maybe i can test it at Brodaks
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dennis Toth
When you go to the link click on the rules section then scroll down to Perky - E Perky.
Any chance of publishing plans?
Best,    DennisT
Dave Rigotti
No published plans. The kit at $70USD includes everything but motor, esc, prop, battery, spinner, and finish. Glue not included of course. It's a excellent value! No need to attempt a scratch build.
Remember guys, as AMA requested from NASS, this is intended as an introduction to control line speed type event using electric power.  Speed has other events for the usual crowd.  Accept it as it is intended.
Quote from: Dennis Toth on May 08, 2026, 08:15:12 AMWhen you go to the link click on the rules section then scroll down to Perky - E Perky.
Best,    DennisT
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dennis Toth
Just to understand one point - the profile fuse is that 1/2" or 3/4" limit? I think in scale they use 3/4" max, I don't know what speed has used?
Best,   DennisT
Fred C
Profile CL Scale uses the 1" max fuselage thickness, CL profile Carrier has the 3/4" fuselage thickness.
I think the rules needs to specify the max thickness of the wings and fuselage just in case someone wants to scratch build from Perky Plans
Fred
I would interpret it like 1/2A Scale.  Profile is PERMITTED, but you could go all the way up to full body if you want.
I doubt that anybody would quibble about wing thickness.
Real Perky has been far too generous, in my opinion, letting inverted and sidewinder engines being the worst offense.
Motorman
AMA use to have a profile fuselage definition based on engine class. Perky would be "A" so 3/8" max? That's plenty enough to be structurally sound and have a bit of airfoil. If you're trying to fully streamline it behind the spinner then you're missing the spirit and intent of the event.
MM :)
Bob Heywood
Just support NASS and buy the kit. You could have it built in less time than you are wasting pounding on your keyboard.
Agree Agree x 1 View List
"Clockwise Forever..."
Dave Rigotti
Amen!
Quote from: Bob Heywood on May 10, 2026, 12:06:29 PMJust support NASS and buy the kit. You could have it built in less time than you are wasting pounding on your keyboard.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dave Rigotti
Also a correction is in order.
It's called PerkE
Dave Rigotti
AMA 66859
Chesterland, Ohio
bill bischoff
Rules question: maximum model weight of 20 oz, with or without battery? It should probably specify.  ???
Motorman
Links to stuff not in the kit please.
MM :)
Quote from: bill bischoff on May 11, 2026, 11:46:31 AMRules question: maximum model weight of 20 oz, with or without battery? It should probably specify.  ???
Considering all the many many limitations, it weighs what it weighs, except for glue & paint.
You have good point, sir.  Maybe it can't be built under 20 ounces.
Dave Rigotti
With battery, ready to launch.
Pull test is a fixed 25#, not 32 times weight for example. Makes for a simpler running event.
I'll revise when i get back from Perth.
This is why all documents are downlaoded and not included in kit.
Thanks Bill!
BTW...prototype came in at 16 1/2oz ready to launch with 3S 1300mah lipo.
Any pics of Bob's build yet?
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dave Rigotti
PerkE rules have been updated to clarify 20oz maximum weight.  It might take overnight to get uploaded to clspeed.org.
They are dated 05 12 2026.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dave Rigotti
Quote from: Motorman on May 11, 2026, 02:08:57 PMLinks to stuff not in the kit please.
Links are in the BOM sheet downloaded from clspeed.org
MM :)
Dave Rigotti
AMA 66859
Chesterland, Ohio
Motorman
Looks like from ground zero you could be up for about $200.
Can you use either prop for CCW flight or is the pusher required?
Can the belcrank be on the outboard side of the fuselage?
How many flights do you get from one battery charge?
Thanks, MM
Getting into an event with an equal chance for $200 is cheap money.
Having flown E-carrier for two years I can say this for sure:  You might get two or three flights off a charge, but each flight will be slower than the first.  Don't bother flying with a battery that is not charged BEYOND the max.
