  • June 17, 2025, 11:30:46 AM
Author Topic: Fox 35 Speed Fantasy Engine Build  (Read 3136 times)
« on: July 10, 2015, 03:29:24 PM »
Ok you know the rules, must use at least the Fox 35 crankcase and must remain plain bushing. Here we go:
Crankcase Fox 35, 50th or 60th anniversary for most metal. Head and backplate bolts tapped 5-40 and motor mount lugs machined flat for pan mount
Piston and sleeve, SuperTiger G21-29 ABC  will fit by taking .010" off the OD
Conrod, 7075-T6 custom length and bushed with phosphor bronze.
No more baffle so head can be billet hemi with turbo plug and generously finned for cooling (plain bushing runs hot)
Crank, custom solid 4130 shaft no timing hole, full circle crank web and counter balance with extended crank pin
Back plate, billet rear valve with SuperTiger disk timing 35/60
Venturi, 5/16" with SuperTiger NVA
Your turn,
Offline C.T. Schaefer
Re: Fox 35 Speed Fantasy Engine Build
« Reply #1 on: July 10, 2015, 04:34:37 PM »
Cool phantasy! But not mine. Got my own. >:D
« Reply #2 on: July 10, 2015, 07:20:23 PM »
There's a whole AMA Rule Book full of events where you can build an engine and not be hindered by the Fix case.
« Reply #3 on: July 12, 2015, 02:05:18 PM »
Tommy, did you find a turbo charger small enough to fit a Fox?
Offline bob whitney
« Reply #4 on: July 12, 2015, 02:27:22 PM »
i have plans for a supercharger
rad racer
« Reply #5 on: July 12, 2015, 06:29:47 PM »
But it still has to be rear valve or the crank will snap right? Isn't there something in the speed rules about super chargers?
« Last Edit: July 13, 2015, 11:28:48 AM by Motorman »
« Reply #6 on: July 13, 2015, 12:05:04 PM »
Supercharges are legal.  Just not compressed gas cylinders.
