  • July 15, 2025, 01:26:19 AM
Author Topic: Bellcrank for Perky  (Read 1656 times)
Offline Chris Sarnowski
Bellcrank for Perky
« on: July 22, 2018, 05:29:50 PM »
Hi Guys,
What type of bellcrank should I be using on a Perky? I am likely using a Fox 15 BB Schnuerle, although that plan might change.
I have Sig nylon 3" bellcranks, some used/recycled F2D bellcranks, and I think I have a few aluminum ones around.
Chris
Re: Bellcrank for Perky
« Reply #1 on: July 23, 2018, 10:20:15 AM »
Thanks MM, the measurements would be helpful. How much elevator throw should the Perky have?
-Chris
Offline jfv
« Reply #2 on: July 23, 2018, 12:57:15 PM »
I use a Brodak 2 inch nylon.  Had some issues with metal bellcranks wearing due to harmonics.  Running a high RPM Super Fora.  No issues with the nylon crank.  Use inner hole.   1/4 inch up and down is plenty of control.
Jim Vigani
« Reply #3 on: July 24, 2018, 06:31:56 PM »
Thanks Jim, good info! Hope to have it done this fall.
-Chris
