  • June 24, 2025, 04:52:47 PM
Author Topic: Vintage Speed  (Read 3238 times)
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
Vintage Speed
« on: July 03, 2007, 07:41:41 AM »
this will be my entry at the Nat's.  an O&R 60 ignition in a 1946 Buzz.
Offline dynasoar1948
Re: Vintage Speed
« Reply #1 on: July 04, 2007, 10:52:44 AM »
Thomas,
Congratulations on a beautiful airplane.  I remember seeing the originals in flight.  Did you increase the wing area?  It looks larger than I recall.   Is the landing gear drop-off or fixed?  Please keep us informed, particularly as to how it flies on official lines.
Good luck at the Nats.
Will
William Stewart
Offline Thomas Wilk
Re: Vintage Speed
« Reply #2 on: July 04, 2007, 11:55:18 AM »
yes we increased the span and adde3d tip weight to offset the heavier lines.  the landing gear is fixed.  the only other change is the metal spinner because i could not get the balsa spinner balanced.  we don't have a 12dx10p prop so we'll go with something close.  i tested the ignition system yesterday.  i'm running a 3 - 1 mix of 70 SAE oil and gas.  we will be happy with a clean flight whatever the speed.  we also have a Magna "B" wiyh a dooling 29.
tawilk
Re: Vintage Speed
« Reply #3 on: July 04, 2007, 07:38:37 PM »
Thomas,
I think you'll find that a 10-10 prop will work fine.  Got good results in my O&R PDQ Senior on both gas & alcohol fuel.
Will
William Stewart
Re: Vintage Speed
« Reply #4 on: July 06, 2007, 07:27:57 PM »
The plane looks fast just setting there.  Wish I had known about the prop requirements.  When I get home after the NATS I will try to remember to see how many I have of Meriwether's old stuff.   Have a big box of all kinds of props that are of wood vintage.  Have fun,  DOC Holliday
Re: Vintage Speed
« Reply #5 on: July 16, 2007, 10:33:03 AM »
Tom,
How did Vintage Speed go at the Nationals?  Have got all the parts for a an Ignition Super Cyclone powered VeeGee, but am holding off for flyability reports on the 0.026 lines.   Briefly considered building this combo for MonoLine, but somehow this would seem to defeat the Vintage concept.
How did the Dooling 29 MagnaModel perform?  Back in the fifties this combo- stock and mild fuel- was good for about 130/135MPH on MonoLine and about five or six MPH slower on U-Control.
Will
William Stewart
Offline Thomas Wilk
Re: Vintage Speed
« Reply #6 on: July 16, 2007, 04:34:38 PM »
as things turned out i was not able to attend with Ashley & Steve due to a minor medical problem.  i'm sure Steve will have a report shortly.
tawilk
Offline Bill Hughes
Re: Vintage Speed
« Reply #7 on: August 02, 2007, 02:55:17 PM »
Hi everyone,
We now have an AMA "Approved" set of Vintage Control Line Speed Rules. See the attachments.
Bill Hughes
Control Line Speed Contest Board Chairman
Offline LARRY RICE
Re: Vintage Speed
« Reply #8 on: September 29, 2007, 09:10:13 PM »
We have sent off for a vintage speed plane called the "Roscoe" the plans were published in 1950. It will be easier than the "Perky" to build and very fast.
Larry
Black Hawk Models
Offline Joey Mathison 9806
Re: Vintage Speed
« Reply #9 on: September 29, 2007, 09:45:54 PM »
wow larry how do you find time to fly you seem very busy
200 mph man ama#9806 joey mathison
Offline LARRY RICE
Re: Vintage Speed
« Reply #10 on: September 30, 2007, 08:45:58 PM »
         I do not fly anymore. My third stroke ended a lot of things including driving and flying. Now I have one goal in life, to share this wonderful sport with as many people as I can. Right now we have 3 new kits at the laser cutters and I should be cutting out a OT Stunter (new kit). Instead an orphanage requested 20 model kits for their kids so that is what I am working on now. When you donate to an orphanage you never expect to get anything back, but once you see the smiles on the kids faces you know that it was well worth it.
Larry  H^^
Re: Vintage Speed
« Reply #11 on: October 01, 2007, 05:00:18 AM »
thanks LARRY  for everything that you do.
