  • June 20, 2025, 06:24:44 AM
Author Topic: Nelson plugs  (Read 6483 times)
Offline bob whitney
Nelson plugs
« on: October 18, 2023, 08:36:16 PM »
how can u tell the difference between nelson hot and cold glo plugs
rad racer
Re: Nelson plugs
« Reply #1 on: October 18, 2023, 10:31:02 PM »
  Basically, Bob, I really doubt there is a difference. See my reply to your post in the main forum. I contacted a company called Aero Engines that sells and services Nelson engines and they show only one Nelson HD plug. the reply that I got from them and have posted posted in the other reply is the most I have been able to find out about them. Some guy is selling Nelson and "Italian Nelson" plugs on eBay and the ones he is calling "hot' have a notch on the hex like I was told by Aero Engines that denotes a HD plug. The Italian versions have a smooth hex and look like the old Standard Nelson plug. If you find out anything else, post it here, please.
Re: Nelson plugs
« Reply #2 on: October 19, 2023, 09:03:19 AM »
Read the other post> S?P D>K
Offline Bill Hughes
Re: Nelson plugs
« Reply #3 on: October 21, 2023, 02:08:51 PM »
Hi Bob,
Why don't you ask Henry?   I always thought that the difference on the one piece Nelson plugs was the size of the hole/cavity were the wire coil sat.  The other post were they talk about the notch in the Hex denote the HD seal If I recall.   With the two piece globee type, Henry offered like 3 different filament diameters.  Blue/Clear .007" Green .010" and Black .012 I think. Henry would be the best person to ask.
With the Italian TCA plugs (Blue Line),  they offer different filament diameters, which give you a heat range.  Smaller dia wire, 0,19 mm smallest, hotest to 0,29 mm coldest.  You can get them in standard spring coil filament and flat coil (glowbee) type filaments.
My Company; B&L Hobby Supplies, Inc imports the TCA brand Glow Plugs.   please contact me at  williamhughes4@att.net if you are interested.
« Last Edit: October 22, 2023, 03:45:45 AM by Bill Hughes »
Offline BillLee
Re: Nelson plugs
« Reply #4 on: October 21, 2023, 06:40:22 PM »
Hi Bob,
What Bill failed to say was that he is a U.S. source for the TCA plugs. He also didn't mention that they also make various heat ranges of Turbo plugs in addition to the Nelson form. All available from him.
Maybe he might add his address.
Bill Lee
AMA 20018
Offline david smith
Re: Nelson plugs
« Reply #5 on: October 24, 2023, 08:13:16 PM »
The regular nelson plug has the hole just bigger than the coil and the other one (that works better with higher nitro and throttling) has a significantly larger hole. I will try to see if I have any to take a pic of tomorrow.
David
