  • June 24, 2025, 06:44:11 PM
Author Topic: Updated Score Sheets for the Nats  (Read 1273 times)
Offline Fred Cronenwett
    • Lafayette Esquadrille
« on: July 08, 2015, 08:21:16 PM »
I recently got a call from someone who will be at the Nats and they were not aware that the Nasa Scale website had all of the forms for the events.
Do yourself a favor and print out the forms and make copies before you arrive. There are two versions on the Nasa Scale website, the Inteligent version allows you type in your name and other information and then print them out, or just print out the blank form and use an old fashioned pen. Make enough copies for 4 rounds of flying and the static judging. I am making a minimum of 4 copies of the static score sheets and 8 of the flight score sheets
http://www.nasascale.org/compdocs.htm
The AMA website has the updated rules and they also have forms there also..
http://www.modelaircraft.org/events/compreg.aspx
I noticed that there are differences between the two forms on the Nasa Scale and the AMA website, the points add up the same but could lead to some differences in how the models are judged based upon which form is used. Look at the Static score sheet for Sport/Team/Profile and you will see the differences
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
