Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 07, 2025, 05:03:15 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Speed,Combat,Scale,Racing
Scale Models
(Moderator:
Leroy Heikes
Tempest .
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tempest . (Read 3190 times)
M Spencer
Trade Count:
0
Admiral
Tempest .
on:
May 08, 2019, 09:21:44 PM »
Actually a Stunt Model . F2B Even . But some of you might figure that out .
However , It IS Scale . But a trifle disproportionate in places .
But we wont tell anyone that . Will We ! .
THAT is not actually a model aeroplane . Im thinking it might be real .
Right , here we go .
All those little bits inside em are already cut . So knock out . After Sheeting . Though it was gunna bee cap strips , were #*^@! of holes in tissue .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #1 on:
May 08, 2019, 09:37:45 PM »
Get in behind . Just as well theres something under it , keeping it ' In Line ' . Tapered scrap customwood . Or high density cardboard as some may call it ,
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #2 on:
May 08, 2019, 09:43:28 PM »
The Squadron Mess .
and custom 1 mm steel dual adjustable leadout guide . 40 thou. to you .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #3 on:
May 08, 2019, 09:49:01 PM »
Seen this somewhere before . Custom Lucky Boxes & 5/32 in. Wire Flap Actuator ( Horn ) ends . Tapered to 1`/16 so its WIDER for bearing interface area .
End View of inboard end of flap .
Ruler etc showing ' sector ' ply ( 1/16 . aint got no thirty two ) faces 3/16 odd at LE of flap , almost 5/8 " aft . So, theyre Tapered AND Tapered .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #4 on:
May 08, 2019, 09:53:50 PM »
Templates for SPAR WEBBS . Darn sight better'n cutting emm to suit . Fit bottom spar , webbs , top spar , weight . jigged .
Custom Jigs FOR SALE . GUARANTEED . Ecept in cases of War, Flood, Earthquake , or acts of God , or the Neigbours .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #5 on:
May 08, 2019, 10:04:15 PM »
Essentially , It THIS plus 18 inches on the nose , and a differant wing. As you may well have seen .
Plus a ' 3 port ' ST 60 PDP . ( A 1970 OS 80 in the Typhoon due to its prospensity for tourque . And Weight . only 1 Oz Noseweight )
We wont mention the other weight ( O/A ) .
Thus is the determination to do the fuselage moulded . Tho it wont be as durable , the plug will suit also a second Typhoon . It will be worth it .
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: Tempest .
Reply #6 on:
May 09, 2019, 11:28:24 AM »
That nose does look short.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Re: Tempest .
Reply #7 on:
May 09, 2019, 12:52:51 PM »
I'm concerned about a steel welded leadout guide. You then must compensate with extra weight on the outboard wingtip. The light ply guides are completely adequate, and light in weight.
Logged
AMA #796 SAM #188 LSF #020
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #8 on:
May 10, 2019, 11:08:19 PM »
I'll be flying it in Hurricanes .
Like the ZERO .
Last Edit: May 21, 2019, 11:36:28 PM by Matt Spencer
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #9 on:
May 11, 2019, 09:48:50 PM »
Pre Cambering leading edge sheet . So it sags UP between the ribs .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #10 on:
May 14, 2019, 12:19:10 AM »
Miscalaeneous drivle
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #11 on:
May 14, 2019, 12:20:19 AM »
Ditto .
Logged
M Spencer
Trade Count:
0
Admiral
Re: Tempest .
Reply #12 on:
May 14, 2019, 12:29:08 AM »
22 Oz ( With Pins ) and inc. 1.25 Oz Flap Horn . And rather stiff 1/2 sheet flaps . Before flatting off and dressing in sanding . As it is there .
Dual rib edge ( 3/16 deep outer ) at diheadral break . Unglued til Arildite at fitting outer skins . So a ' T ' of Adhesive along the join .
HENCE the Masking Tape or it tends to get messy .
Was anticipateing doing nice ROUND wingtips , However ;
Theres a few of these ' Walkarounds ' on the knett ,
wkertempest.se/index.php/indetail/walkarounds/298-walkaround-hawker-tempest-mk-v-tt-nv778
Zillions of pretty pictures .
Just as well , too .
Logged
Chris McMillin
22 supporter
Trade Count:
0
Admiral
AMA 32529
Re: Tempest .
Reply #13 on:
May 19, 2019, 06:39:31 PM »
When I went to Hendon in 1989 the Typhoon, Tempest and Fury were lined up together and were painted in late camo and looked so great. I hate the target tug paint on the Tempest. Sometimes actual airframe historic paint sucks.
Chris...
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Scale Models
(Moderator:
Leroy Heikes
Tempest .
