  • June 17, 2025, 07:49:04 AM
Author Topic: Tempest .  (Read 3110 times)
Tempest .
« on: May 08, 2019, 09:21:44 PM »
Actually a Stunt Model . F2B Even . But some of you might figure that out .
However , It IS Scale . But a trifle disproportionate in places .  :-X But we wont tell anyone that . Will We ! .
THAT is not actually a model aeroplane . Im thinking it might be real .
Right , here we go .
All those little bits inside em are already cut . So knock out . After Sheeting . Though it was gunna bee cap strips , were #*^@! of holes in tissue .
Re: Tempest .
« Reply #1 on: May 08, 2019, 09:37:45 PM »
Get in behind . Just as well theres something under it , keeping it ' In Line ' . Tapered scrap customwood . Or high density cardboard as some may call it ,
Re: Tempest .
« Reply #2 on: May 08, 2019, 09:43:28 PM »
The Squadron Mess .  :-[ and custom 1 mm steel dual adjustable leadout guide . 40 thou. to you .
Re: Tempest .
« Reply #3 on: May 08, 2019, 09:49:01 PM »
Seen this somewhere before . Custom Lucky Boxes & 5/32 in. Wire Flap Actuator ( Horn ) ends . Tapered to 1`/16 so its WIDER  for bearing interface area .
End View of inboard end of flap .
Ruler etc showing ' sector ' ply ( 1/16 . aint got no thirty two ) faces 3/16 odd at LE of flap , almost 5/8 " aft . So, theyre Tapered AND Tapered .
Re: Tempest .
« Reply #4 on: May 08, 2019, 09:53:50 PM »
Templates for SPAR WEBBS . Darn sight better'n cutting emm to suit . Fit bottom spar , webbs , top spar , weight . jigged .
Custom Jigs FOR SALE . GUARANTEED . Ecept in cases of War, Flood, Earthquake , or acts of God , or the Neigbours .
Re: Tempest .
« Reply #5 on: May 08, 2019, 10:04:15 PM »
Essentially , It THIS plus 18 inches on the nose , and a differant wing. As you may well have seen .
Plus a ' 3 port ' ST 60 PDP . ( A 1970 OS 80 in the Typhoon due to its prospensity for tourque . And Weight . only 1 Oz Noseweight )
We wont mention the other weight ( O/A ) .
Thus is the determination to do the fuselage moulded . Tho it wont be as durable , the plug will suit also a second Typhoon . It will be worth it .
Re: Tempest .
« Reply #6 on: May 09, 2019, 11:28:24 AM »
That nose does look short. D>K
Re: Tempest .
« Reply #7 on: May 09, 2019, 12:52:51 PM »
I'm concerned about a steel welded leadout guide.  You then must compensate with extra weight on the outboard wingtip.  The light ply guides are completely adequate, and light in weight.
Re: Tempest .
« Reply #8 on: May 10, 2019, 11:08:19 PM »
I'll be flying it in Hurricanes .
Like the ZERO .
« Last Edit: May 21, 2019, 11:36:28 PM by Matt Spencer »
Re: Tempest .
« Reply #9 on: May 11, 2019, 09:48:50 PM »
Pre Cambering leading edge sheet . So it sags UP between the ribs .  ;D
Re: Tempest .
« Reply #10 on: May 14, 2019, 12:19:10 AM »
Miscalaeneous drivle
Re: Tempest .
« Reply #11 on: May 14, 2019, 12:20:19 AM »
Ditto .
Re: Tempest .
« Reply #12 on: May 14, 2019, 12:29:08 AM »
22 Oz ( With Pins ) and inc. 1.25 Oz Flap Horn . And rather stiff 1/2 sheet flaps . Before flatting off and dressing in sanding . As it is there .
Dual rib edge ( 3/16 deep outer ) at diheadral break . Unglued til Arildite at fitting outer skins  . So a ' T ' of Adhesive along the join .
HENCE the Masking Tape or it tends to get messy .
Was anticipateing doing nice ROUND wingtips , However ;
Theres a few of these ' Walkarounds ' on the knett ,
 wkertempest.se/index.php/indetail/walkarounds/298-walkaround-hawker-tempest-mk-v-tt-nv778
Zillions of pretty pictures .  :P Just as well , too .
Re: Tempest .
« Reply #13 on: May 19, 2019, 06:39:31 PM »
When I went to Hendon in 1989 the Typhoon, Tempest and Fury were lined up together and were painted in late camo and looked so great. I hate the target tug paint on the Tempest. Sometimes actual airframe historic paint sucks.
Chris...
