  • June 18, 2025, 05:05:26 PM
Author Topic: Model Aviation CL scale Column Correction  (Read 1922 times)
Offline Fred Cronenwett
    • Lafayette Esquadrille
« on: November 21, 2014, 07:25:03 PM »
I guess I didn't read proof read the column carefully enough before it got printed....Bob Whitney's 1/2a scale model at the 2014 Nats was not flying with an 0.61 size engine....! I not sure a 1/2a scale model could even stay together with a .61 engine attached and it would go really fast.
it should have said .061 engine! My fault on that error
Fred Cronenwett
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Mike Keville
Re: Model Aviation CL scale Column Correction
« Reply #1 on: November 21, 2014, 07:34:58 PM »
No sweat, Fred.  We knew what you meant.
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
« Reply #2 on: November 21, 2014, 07:56:25 PM »
Ditto what Mike said.
Blessings
Allen
« Reply #3 on: November 22, 2014, 11:53:02 AM »
Not a big deal, Fred.  I think you are doing a great job with the column, so keep up the fine work.
« Reply #4 on: November 22, 2014, 12:45:09 PM »
So, if Cyclon made an 061, would it generate more power than a Brown Jr.?
And if you put a Brown Jr. on a 1/2A plane, would you have prop clearance?
Offline bob whitney
« Reply #5 on: November 22, 2014, 07:18:40 PM »
 i wont hold it against you
Fred Cronenwett
rad racer
« Reply #6 on: November 23, 2014, 08:47:23 AM »
Two pages out of 162.  Who says there's no CL in Model Aviation?
If it weren't for electric motors and radios in CL planes, we probably wouldn't even get this.
