  • July 18, 2025, 07:41:33 PM
Author Topic: Scale Contest at Huntersville NC Oct 18 2008  (Read 1906 times)
Offline Will Davis
« on: October 05, 2008, 06:24:39 PM »
Attached is a flyer for the Contest at Huntersville NC Contest , F4B Scale , no Appearance points , no BOM , Just Fly
Will Davis
Will Davis
"Carolina Gang"
Offline John Rist
Re: Scale Contest at Huntersville NC Oct 18 2008
« Reply #1 on: October 06, 2008, 12:40:05 PM »
 ??? What is F4B Scale?  I am new to all this.
Offline John Rist
« Reply #2 on: October 06, 2008, 03:50:05 PM »
FAI CL scale.
I know that.  But what is it?? Sport, Profile, ?????
Offline chuck snyder
« Reply #3 on: October 06, 2008, 07:05:43 PM »
Fai has a different flight schedule--and a different style of static judging. But there will not be any static judging at Huntersville--just flying to the FAI rules.
Offline John Rist
« Reply #4 on: October 06, 2008, 08:58:46 PM »
Ok. That makes sense. If I understand FAI flying rules the up-down control of the airplane flight path must be mechinical.  I.E. My Extra 300S uses servos to power the elevator and therefore it would not be FAI flight legal. True?  HB~>
« Reply #5 on: October 07, 2008, 03:02:03 AM »
John,
I think that the contest is more of a flight schedule practice, there is no static scoring, and there is no builder of the model (BOM) rule, so it sounds low key, fly what you brought.
More than likely the CD will be more than happy to see another competitor show up and fly. Call him and see for sure.
Download the FAI rules off of the AMA site and see the differences between FAI and AMA, and then you will have a notion of what the flying rules will be before you get there.
Have fun,
Chris...
« Reply #6 on: October 07, 2008, 08:40:55 AM »
Here all this time I thought the elevators were supposed to be controlled by the pilot using a handle, lines and bellcrank.  Servos can be used for throttle and any other function of the aircraft.  DOC Holliday
Offline John Rist
« Reply #7 on: October 07, 2008, 10:14:26 AM »
DOC,
All true,  However on my Extra 300S the pilot, using a handle, two lines and a bellcrank controls a servo driver via a link between the bellcrank and a pot.  The servo driver then controls the servos that operate the elivator and alerons (rigged as flaps).  The advantage is two fold. First of all this is a big airplane and it makes it easy to remove the wing.  I haul this beast in a standard size 4-door sedan.  And second of all it requires very little line tension to maintain controll. So when things go badly and lines go slack I may still have controll.
Any way, is it goffey? - yes. Does it work? - YES !!!!
« Reply #8 on: October 08, 2008, 08:16:38 AM »
It has been pointed out to me that you are very legal as long as you are using pulses down the lines and no radio signals.  What happened to the simple days?  DOC Holliday
Offline John Rist
« Reply #9 on: October 08, 2008, 09:12:20 AM »
Bell labs, Bill Gates, IBM, Microsoft ---------  S?P
As I said before I know the electronics.  Where I am hurting is in my building skills. At this point I am not much of a threat at a contest but I am having FUN!!!  #^
« Reply #10 on: October 08, 2008, 09:15:23 AM »
HAVING FUN, that is the main thing.  DOC Holliday
