  • June 17, 2025, 02:20:39 PM
Author Topic: Electric power with throttle control  (Read 1603 times)
Offline Allan Perret
  • Proverbs
« on: February 03, 2016, 08:02:02 PM »
What are the options for throttle control when using E power ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Electric power with throttle control
« Reply #1 on: February 03, 2016, 08:34:57 PM »
Hi Allan
John Brodak asked Will Hubin to design a throttle system that is controlled via a normal 3-line handle.  Pete Klepsic (SP?) installed the system in one of his B-25's.
Here's a link:
http://brodak.com/electric-accessories-1/timers/timer-fm-etc-for-scale.html
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #2 on: February 03, 2016, 08:47:04 PM »
You can also use 2.4 Ghz with a receiver in the model, the system is wireless. You can have a trigger on the handle or hang the transmitter on your hip
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #3 on: February 03, 2016, 09:16:08 PM »
Hi Allan
Here's a link:
It's Aunti-Servo, only with a different mechanical arrangement and actually available commercially!
Dennis, have you used one?  When I was considering measuring elevator position in a stunter for recording flights, I did not use a slide pot because of the amount of friction in the ones that I've used -- with heavy emphasis on the ones I've used.  That's why I gut servos and put in my own electronics -- the friction is minimal.
