  • July 11, 2025, 08:42:14 AM
Author Topic: RSM .15 size P-51 Flies in scale, WINS!  (Read 4309 times)
Online Larry Renger
« on: August 10, 2015, 09:11:37 AM »
Well, OK, I was the only entry in my class, but I did score 87 points in my first scale contest. Plus the plane survived unscathed.  LL~
Re: RSM .15 size P-51 Flies in scale, WINS!
« Reply #1 on: August 10, 2015, 11:51:51 AM »
Well congrats on the win.  If you hadn't flown there would have not been a winner.
Offline MarcusCordeiro
« Reply #2 on: August 10, 2015, 12:49:46 PM »
"It don't matter if it's by na inch or a mile, winning is winning..."
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Mike Lauerman
« Reply #3 on: September 16, 2015, 11:41:40 AM »
Excellent detail, especially the pilot clone of Bob Hoover. Congrats on your win!
« Reply #4 on: September 18, 2015, 11:13:27 AM »
A very nicely done ship!  I hope you ad more scale ships to your stable, scale needs guys like you!
Online Larry Renger
« Reply #5 on: November 25, 2015, 10:07:47 AM »
I added a KR timer to the other side of the fuselage so I can fly stunt with the model too.  ;D
I am working on the handle setting and other trim. I use a modified RC car radio for the handle in scale, but an RSM Hard Point Exponential handle for stunt. So far, the same lines for both, 52.5' x .012.  I may go to 2' shorter lines for stunt, as the overhead maneuvers are more difficult than what you need for scale. Plenty of maneuvering capability available.
So far the plane has great potential, I scored 509 with a similar model that weighed 2 ounces more! When tuned for stunt will fly scale even better, I expect.
Offline big ron
« Reply #6 on: February 08, 2016, 03:43:46 PM »
Mr Larry I have the kit not built yet for glow. Just curious to what the weight is ?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Online Larry Renger
« Reply #7 on: February 28, 2016, 07:51:25 AM »
It weighs 26 ounces with a 2200 mah 3s battery.  That is a bit too heavy to really fly stunt well, it sags a bit in hard corners.  the 2200 is needed for the modern pattern, but I can get away with a 1500 for scale, and lose nearly 1 ounce, plus the maneuvers are way less demanding. Now that I have my Ringmaster, I will probably only fly this model in scale events.
Offline Bill Heher
  • Fix-it
« Reply #8 on: March 21, 2016, 01:02:39 AM »
With the spirit of Bob Hoover under the canopy- it is bound to be a winner!
Bill Heher
If it's broke Fix-it
« Reply #9 on: March 21, 2016, 07:03:09 AM »
Did you mount the battery on the inboard side? I am almost finished with mine and am thinking about doing that.
Thanks .Looks great.
Online Larry Renger
« Reply #10 on: March 26, 2016, 06:42:47 AM »
The battery is mounted under the outboard wing.
