  • June 19, 2025, 07:22:33 AM
Author Topic: Profile scale CL model  (Read 2645 times)
Offline julio carmo
« on: December 06, 2014, 06:51:16 AM »
Hi
Wehre can I get a plan for the P51 Mustang, profile fuselage, for control line, engines 1.5cc or 2.5cc?
Julio
Re: Profile scale CL model
« Reply #1 on: December 06, 2014, 08:37:10 AM »
Hi
Julio
Julio,
Welcome!
Did you mean .15cc and .25cc ?
Offline John Rist
« Reply #2 on: December 06, 2014, 08:44:15 AM »
I would think he meant 1.5cc  or 2.5cc  that is a .09 or a .15 size engine.  I am sure some one will respond with a source for the plans.
« Reply #3 on: December 06, 2014, 10:17:29 AM »
John,
Guess I have my CC's mixed up.  n~
I just picked up a Balsa USA Mustang kit.
The Mustang is a great aircraft to model, in any size.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #4 on: December 06, 2014, 11:12:30 AM »
I have taken plans that show a full bodied model and just build the profile fuselage to match the side shape on the plans. You can almost take any set of plans even if they are too small or large and have a copy made to the size you want. FedEx/Kinkos has large copiers that can enlarge and shrink plans and 3-views. just make sure the outlines are good enough if you plan on entering any contests with it.
Or you can take your favorite 3-view and have that enlarged to the span you want.
This our CL club website here in St Louis with some info or CL scale. When I built the B-29 model I just enlarged the 3-view to the size I wanted and then sketched in the construction techniques on that copy.
Fred Cronenwett
http://lafayetteesquadrillecl.wordpress.com/lafayette-esquadrille-cl/cl-models/scale/
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #5 on: December 06, 2014, 11:40:48 AM »
A modern 2.5cc engine will produce as much power as a 1950's 3cc engine (if anyone had made such, then).  So you may want to mention the specific engine, or engines, that you have in mind and ask for what's a good plane size.
Outerzone has a good plans listing.  So does Hip Pocket Aeronautics.
Try this.  There's a bunch of rubber freeflight planes in the list, but also some CL planes about the right size:
http://www.outerzone.co.uk/advanced/search_advanced/results.asp?Tag1=Scale&Tag2=*&Tag3=*&Year1=0&Year2=2014&Span1=24&Span2=30&Keyword1=Mustang&KeywordField1=TextNotes&Keyword2=*&KeywordField2=PlanTitle&Submit=Search
Offline Gordon Van Tighem
Gord VT
MAAC 3738L, Life Member
AMA C3738L
