  • June 16, 2025, 02:19:00 AM
Author Topic: Printing your own score sheets.  (Read 1296 times)
« on: May 22, 2025, 09:02:14 AM »
file:///C:/Users/User/Documents/airplanes%20NOPQRS/scale/Control_Line_Scale_2024-2025.pdf
The above link is the AMA Rule for scale.  The score sheets are pages 48-53.   I was able to down load this as a pdf.  But pdf is made so you can't edit it.
I would like to be able to prepare score sheets in advance in lieu of hand writing them at the contest.  The only path I can see is to print the sheets and then scan them back into the computer, then type on a copy in PowerPoint, Word, or Excel.
Offline Pete Bauer
Re: Printing your own score sheets.
« Reply #1 on: May 28, 2025, 11:23:40 AM »
Paul - I have always just printed out a blank sheet, filled it in with my information, then run multiple copies for static judging and flight judging.  Nothing fancy.
