  • July 09, 2025, 03:32:08 PM
Author Topic: engine test stands  (Read 1128 times)
Offline Fred Cronenwett
    • Lafayette Esquadrille
engine test stands
« on: November 12, 2013, 04:45:37 AM »
One of the valuable tools are engine test stands, I like to make stand alone units that can be placed on the ground and not clamped to anything. The smaller unit was built with two different mounts based on the size of the engine out of surplus plywood and cans. This test stand is large enough to run an OS-91FX engine.
When I was planning my B-29 I put together a unit that could run the 4 engines, I tested both glow and electric, the picture shows the glow version of the test stand. I even put servos on it to control the throttle to see if I could get the engines to sync together.  At the end of this testing I was able to get all four OS-25FP's to sync together but went with the electric power instead.
Fred Cronenwett
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
Re: engine test stands
« Reply #1 on: November 12, 2013, 06:30:20 AM »
Fred, I like it! I have all the "surplus" items in my barn and I am going to make one, thanks.  #^ #^ #^
Blessings
Allen
