  • July 10, 2025, 06:28:05 PM
Author Topic: p-51 props and spinners  (Read 927 times)
Offline fernando torres
« on: September 03, 2011, 05:35:00 AM »
Where can I find 4 blade props and spinners for a p-51?  With regard to spinners, the ones I have seen look" too pointy" not to scale.
FET
Online John Rist
Re: p-51 props and spinners
« Reply #1 on: September 03, 2011, 07:46:27 AM »
Tru-Turn  has 4 bladed spinners,  If you start with their home page go to spinners - shapes - size - etc.  By the way they come in colors but they are anadized which is shinney.  I suppect you will have to paint.  They are aluminum so probbly will need priming.
http://www.truturn.com/cgi-bin/store/agora.cgi?p_id=tt25604b115:16&ppinc=spinners160&exact_match=on
APC makes 4 bladed props.   What size P-51 are you building?  Electric or gas?
Offline roger
« Reply #2 on: September 03, 2011, 08:50:31 AM »
what i do ,because i dont fly with that , only for show, is buy 2 props  the same make sure they are exactly the size  you want. put it on a band saw and cut off   around the hub , lay your other one out  the two halfs will now make your 4 blader. rough up  lay flat the areas to be epoxied togther stick um togther now get your spinner and cut to fit  H^^
Offline bob whitney
« Reply #3 on: September 11, 2011, 11:17:11 AM »
what size engine and props are you using .with 4 blades you wont want much pitch .i made the carbon 4 blade props for my Pond racer  also the carbon spinners . also made spinners for Keith Trostle and Leroy Blasck, Bob Whitney ( not Whitely).
rad racer
