  • June 19, 2025, 02:49:58 PM
Author Topic: scale operations  (Read 1495 times)
Offline bob whitney
scale operations
« on: March 15, 2014, 02:55:34 PM »
 under scale operations if u are flying a fighter plane ,controlline can u do a manuver that would represent approching an enamy plane and retreating to gain points
rad racer
Offline John Rist
Re: scale operations
« Reply #1 on: March 15, 2014, 10:20:33 PM »
The problem is defining the maneuver and explaining it to the judges.  Speeding up and slowing down would be a little weird to call it an maneuver.
Offline bob whitney
« Reply #2 on: March 16, 2014, 09:10:04 AM »
it would be more complacated than that ,but i see your point.  it would be a combination of a dive going back inverted then finishing a loop to get back into position
rad racer
Offline John Rist
« Reply #3 on: March 16, 2014, 10:37:24 AM »
If your scale airplane is capable of this it would be a great maneuver!  Most scale aircraft have the problem of being heavy and don't stunt that well.  Any maneuver is acceptable if it is within the flight envelope of the real aircraft.  As I said before, if it is outside of the usual flight plans you need to make the judges aware ahead of time of what you are planning.  I have an Extra 300S with smoke.  I tell the judges as I hand them my score sheets that I have a maneuver called smoke.  I tell them that I will fly at least 3 laps with the smoke on. Also I will be climbing and diving during the laps.  I usually fly at least 4-5 laps. It has always scored high.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #4 on: March 16, 2014, 05:53:00 PM »
The judges are looking for options that the full size aircraft was capable of doing. Most fighter were capable of limited aerobatics, but could not perform inverted fllight in excess of 10 seconds.
Remember if it is a fighter flly it like a fighter and limited aerobatics would be possible.
The judges have a common set of options that folks typically use and what you described does not seem to fit a commonly used option and might be hard to explain to the judges.
If you can do a loop then call it out and only do the loop, just make sure the full size was capable of doing a loop
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline bob whitney
« Reply #5 on: March 16, 2014, 06:14:48 PM »
i was looking for something diff
rad racer
