CLICK HERE--><--CLICK HERE
modifying a spektrum dx 5c radio for c/l scale
Started by Matt Curtis, January 18, 2026, 02:53:30 PM
Previous topic - Next topic
0 Members and 3 Guests are viewing this topic.
Matt Curtis
are there any video on you tube that shoe how to modify a r/c car radio for c/l scale? I was wondering how to use the extra channels for flaps and retracts. Not too hard to make a handle set up for the radio? would need to know how to put switches on there to operate flaps and retracts if that could be done? I already have an airplane radio so this would have to be easy to do or I wo'nt do it?
Pete Bauer
A starting point is the Feb 2026 article by Fred Cronenwett in Model Aviation "A Brief History of CL Throttle Control"  https://www.modelaviationdigital.com/modelaviation/library/item/february_2026/4316308/
There is no right or wrong answer.  As Fred described, there are many different ways to accomplish what you are asking about.  When you read the article...
1) You see a photo of Fred with a "airplane" transmitter hanging off his belt.  Many pilots use this method - standard throttle control on the left joystick with retracts and flaps tied to toggle switches on the top of the transmitter.
2) You see a photo of Mike McHenry simply holding a "car" transmitter in his left hand with the model handle in the right hand.  He uses the standard transmitter trigger for the throttle.  Note that this only works if your model is throttle only without retracts / flaps.
3) You see a photo of me flying with the Spektrum DX5 transmitter integrated with my handle.  Since I do not like to fly throttle on a trigger (just my preference), I use the steering wheel for throttle control (after removing the centering spring).  The transmitted has multiple toggle buttons on the stem - one is linked to my flaps.  I plug the throttle into the receiver "steering" channel and the flaps into the receiver "aux" channel.  The setup took a little transmitter programming (trial and error) to get the endpoints correct, but now I fly all my planes off the same DX5 transmitter.
4) Not shown, but YES, you can completely dismantle the transmitter and repackage all the components in a box that hangs off you handle.  Need to be careful doing this so that you do not ruin the transmitter.
One issue caught me offguard.  For Spektrum radios, "ground" receivers (cars) only bind with "ground" transmitters, while "air" receivers (planes) only bind with "air" transmitters.  You cannot mix and match.
Before you decide, think about how you like to fly - one hand or two?  Are you OK with a throttle trigger?  I like everything at my fingertips so that I do not have to take my eyes off the plane when searching for that toggle switch.
PM me if you want to talk - this might be more of a conversation instead of a post.
Quote from: Matt Curtis on January 18, 2026, 02:53:30 PM
Easy enough.
Throttle for throttle.
Steering with spring removed for flaps.
Channel 3 for landing gear.
I like transmitters with four dry cells ( 6 volts) rather than the 3.7v lipo type.  Any $30 car/boat set will do.
Matt Curtis
thank you for the info. I am not going to do this as I have an airplane radio with lots of receivers that I use already with no mods needed. I am used to flying with it with the belt clip. the recievers for the airplane radio are way cheaper than the car receivers. Having to mod the car radio is more work than using the airplane radio . The only reason I might do this is if I can't sell the r/c vehicle that uses this radio?
john e. holliday
Now Matt go read the article as Pete beat me to the punch on the article.   I still have my set up for a Class II plane that worked ok.  Just not enough practice. on my part. S?P
Pete Bauer
Quote from: Matt Curtis on January 19, 2026, 08:11:45 PM
If there is nothing forcing you to change setup (ie, old transmitter died), and you are comfortable with the belt clip, then I would say do not change.
When I switched from transmitter in a tray (I fly RC that way) to the car radio on the handle, it took some time to get used to the difference.  I was forced to change because I was flying on an older Airtronics radio that I was concerned about.  Many practice flights to make the transition.
Matt Curtis
Lots of things to consider about making a switch. I have been flying belt clip for many years. I have a electric profile p51 with lights on it to fly in the dark. I have also flown several r/c planes converted to c/l with throttle. It is hard to get c/l flyers that I know to try doing this.  I enjoy doing touch and goes and the other things you can do with it. It is a different mindset to fly scale as opposed to stunt. using 2.4 is easier than 3 line .
bill bischoff
#7
I am working on this right now. Go to Amazon and search "Hot RC". They have a four channel pistol grip Tx with 2 Rx's for $36.00, The handle is hollow to hold the battery pack. I moved the battery to the outside, and fitted an aluminum handle frame inside the plastic shells, For extra strength I potted in with epoxy and microballoons so the handle is more solid to hold the pull test.
Throttle and the steering joystick are the two proportional channels, and there are also 2 push button non proportional channels. For $36 with 2 receivers, how can you go wrong? I am going to use mine for carrier. besides the throttle, I will use full left steering to release the line slider, and full right steering to drop the hook. This way I can get both functions with a single servo and single channel. Ultimately, I will write a full article on this. If I can't get AMA to print it, I will submit it to the Carrier Society Newsletter and send it to Pete Bauer as well.
Pete Bauer
Quote from: bill bischoff on January 20, 2026, 09:41:17 PM
Throttle and the steering joystick are the two proportional channels, and there are also 2 push button non proportional channels. For $36 with 2 receivers, how can you go wrong? I am going to use mine for carrier. besides the throttle, I will use full left steering to release the line slider, and full right steering to drop the hook. This way I can get both functions with a single servo and single channel. Note that in the pictures, the battery is not shown, and the cable that will actually attach the lines has not been installed. Ultimately, I will write a full article on this. If I can't get AMA to print it, I will submit it to the Carrier Society Newsletter and send it to Pete Bauer as well.
Bill - for $36, you cannot go wrong.  Fitting your handle with epoxy in the pistol grip looks great.  Keep me in the loop as you complete and test out.  My only problem is that I prefer throttle on a dial, not a trigger (I never got comfortable with a trigger).
bill bischoff
Pete, in carrier we are constantly moving the throttle, so the trigger is appropriate. In scale, you don't constantly jockey the throttle, you typically set an RPM for a given task (except landing, of course). Did you reach that conclusion consciously, or did it just work out better for you?
Pete Bauer
Quote from: bill bischoff on January 22, 2026, 02:13:56 PM
Yes, in scale very little jockeying of the throttle and even then it is very smoothly applied (unlike carrier).  I tried trigger and just could not get a smooth response.  That said, Mike McHenry flies his L-4 Grasshopper (F4B) very smoothly with a trigger throttle, so it must be me.  As mentioned above, there is no right way / wrong way, it is whatever you are comfortable with.
I might purchase one of the radios you suggest and try to use the steering (L/R) channel for throttle after removing the centering springs and installing a ratchet if possible.
Fred C
Matt
The big question you need to decide is how many channels you need and then, are a traditional stick, toggle or a dial. And what they are going to operate.
I like to use a 3 position toggle for flaps
2 position for retracts, but a 3 position will also work for retracts, it just won't do anything at the middle position
You will find that you are always making slight adjustments with the throttle especially during landing and takeoff. The traditional transmitter will stay the position you leave it if you take your finger off the throttle stick. If it's windy and you need to add more power you can quickly change the throttle setting.
The Hot RC item has Merit like Bill showed with his modifications.
However I really do like these features that come with a modern 2.4 Ghz transmitter
1. Model memory
2. End point adjustment
3. Servo reversing
4. Servo speed adjustment (allows flaps to lower slowly instead of moving quickly to the down or up position)
5. Ability to select the toggle switch for a specific channel. Example for channel 5 I select select a specific toggle switch for flaps and another for retracts on channel 6
When I fly my SBD Dauntless with throttle, flaps and retracts you have to look closely to see how I control the throttle, raise or lower the flaps, then the retracts with small movements of my fingers
Fred
Pete Bauer
Fred - the transmitter Bill showed does most of what you listed including end point adjustment, servo reversing, servo speed adjustment, etc.  I am checking out other transmitter models at Hot RC including this six channel version https://en.hotrc.cn/product/4.html for less than $30.  At this price, I'll try one out - about 1/4 what I paid for my Spektrum.  This one has pushbutton for channel #3, switch for channel #4, and pushbuttons for #5 and #6.
At this price it is worth a try.
bill bischoff
I am building another transmitter handle with the Hot RC transmitter, and taking pictures as I go to supplement a how-to article. Possibly of interest, this one has a 4x1100 mAh Ni-MH battery inside the hand grip.
Pete Bauer
Quote from: bill bischoff on February 04, 2026, 05:51:28 PM
Very nice Bill - What size aluminum stock are you using and how are you bending it so smoothly?
bill bischoff
The aluminum is 1/8" x 3/4", out of the rack at the home improvement store. I built a bender that is very similar in design to the K&S wire bender. There are lots of places that I can fudge the bends a little bit if it all doesn't line up perfectly. I also have a Harbor Freight bending brake that I use sometimes for simpler handle shapes.
Fred C
On the transmitter I use there are two toggle switches right above the throttle stick. With my fingers on the throttle stick I can reach up with my thumb and drop the flaps. Then if I move over to the other toggle switch that is the retracts.  The transmitters I use has a long toggle switch that I use for the flaps and the shorter one next to it is used for the retracts.
There are lots of ways to do it, regardless of which one you pick practice with that system so that it is becomes part of your normal routine. There is no one right way to get it done.
Fred
bill bischoff
Pete, can you post a couple of photos of your Tx/ handle? I might have an idea or two.
Matt Curtis
Thank you all for all of this info. I think I will use the radio I already have as I dont have to modify it and I have lots of recievers. I did go to the hot r/c website to look real quick could not figure out how to order one off of that website? are the recievers cheap? the receivers for my spektrum car radio are more expensive than the airplane radio plus having to mod the car radio and adapting to the new style of flying. Let us know how the hot works if you get one and get it working? Sorry looks like you can order from Amazon according to Bill. I forgot to check that again.
Pete Bauer
Couple of photos below -
Kathy flies left handed and uses the steering wheel channel for throttle control (with steering centering spring removed).  She has access with her thumb for three position switch (typically for flaps) and other programable two position switch (typically for retracts).  All buttons/switches are right there - you do not have to look down at the handle while flying to find a button.
I fly right handed and program the small dial for throttle control.  Also have easy access to three-position switch for flaps and two position switch for retracts.
I do like being able to program the servo speed for the flaps and retracts to make it more realistic.  And YES, that is an old Fox handle that fits perfectly.
Some folks just prefer the finger trigger for throttle - I just never got used to it.  I tell folks there is not a right or wrong way - whatever you feel comfortable with is the way to go.
bill bischoff
#20
Please delete
bill bischoff
The first photo is my recent DX2E conversion. I removed the steering wheel and installed a lever in its place. For my purpose I still wanted the centering spring, but it would be easy to remove. For throttle, the spring would be removed and a nylon or fiber washer could be placed between the case and the lever for a little bit of friction. The middle photo shows my first DX2E conversion from 2011. Note the different antenna. The side of the case was originally contoured similar to the steering wheel side, so I sliced off some of it and replaced it with a flat piece of plastruct plastic. I made sure there was enough depth to mount the steering pot inside the case half. It may be possible to move the actual throttle pot, since the trigger is not needed Instead of the knob, a lever could also be used for the throttle if desired. The last picture shows the empty space inside the transmitter. Since all the brains are in the top of the case, the handle can be cut off. Cover the holes in the case where the handle used to be with more of the same flat plastruct. Bolt your Fox handle to it, screw a plastic battery box the the bottom, and you're good to go. However, if there are any switches mounted in the handle of the radio, you will need a plan B. Note that you could also mount the "brain" on top backwards, so the steering wheel would be on your left side for easier access if it was used for throttle.
Pete Bauer
Quote from: bill bischoff on March 04, 2026, 10:42:42 PMThe first photo is my recent DX2E conversion. I removed the steering wheel and installed a lever in its place. For my purpose I still wanted the centering spring, but it would be easy to remove. For throttle, the spring would be removed and a nylon or fiber washer could be placed between the case and the lever for a little bit of friction. The middle photo shows my first DX2E conversion from 2011. Note the different antenna. The side of the case was originally contoured similar to the steering wheel side, so I sliced off some of it and replaced it with a flat piece of plastruct plastic. I made sure there was enough depth to mount the steering pot inside the case half. It may be possible to move the actual throttle pot, since the trigger is not needed Instead of the knob, a lever could also be used for the throttle if desired. The last picture shows the empty space inside the transmitter. Since all the brains are in the top of the case, the handle can be cut off. Cover the holes in the case where the handle used to be with more of the same flat plastruct. Bolt your Fox handle to it, screw a plastic battery box the the bottom, and you're good to go. However, if there are any switches mounted in the handle of the radio, you will need a plan B. Note that you could also mount the "brain" on top backwards, so the steering wheel would be on your left side for easier access if it was used for throttle.
Thanks Bill - very nice.
