  • July 11, 2025, 08:19:14 AM
Author Topic: larger Line Diameters for 2015  (Read 1236 times)
Offline Fred Cronenwett
    • Lafayette Esquadrille
« on: July 03, 2014, 10:49:58 AM »
One of the items changing in the new proposed CL scale rules is the line diameters. Bottom line they are going up and here is the first good explanation I have seen that explains the engineering behind the rationale to make the wire diameter larger. If you fly large CL scale models like I do you will be affected
This cross proposal is worth reading
There are other Cross Proposals that are worth looking at on the AMA website
https://www.modelaircraft.org/files/CLSC15-4CP2.pdf
Be prepared to cut new lines for your models int 2015!
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Re: larger Line Diameters for 2015
« Reply #1 on: July 03, 2014, 09:40:34 PM »
Having briefly read the very long and technical article, I find the following:
Ted is correct is his contention that the combination of heavy models, high power, and short lines places some models in a dangerous condition.
Ted is correct is his contention that the 60 MPH speed limit, which is essentially impossible to enforce with certainly, is an unacceptable way to rationalize flying heavy models on short thin lines.
I believe Ted's proposal doesn't do enough to formally ban the use of short lines on heavy models.  This is one practice that can drastically increase stress on the lines.  I have no knowledge of anybody actually using short lines on on heavy models, but if we're closing the loopholes we should cover this at this time.  Here is my opening offer:
Up to 0.5 pound minimum length 25'
0.5 to 1.0 pounds minimum length 35'.
1.0 to 2.5 pounds minimum length 52'.
2.5 to 8 pounds minimum length 60'.
5 to 8 pounds minimum length 65'.
8 to 12 pounds minimum length 70'.
I'm already in compliance with both Ted's proposal and my amendment.  I'm sure most other scale flyers are, too. Who wants to spend all that time & money on a model and destroy it trying to skimp on lines?  Leave that to the stunters.
Lines are chump change in the world of what you pay for a scale plane.  F2D flyer wreck four sets of lines a routine contest and think nothing of it.  Speed and racing have automatic line upgrades when somebody sets a new record.
Offline Douglas Ames
« Reply #2 on: July 05, 2014, 03:55:07 PM »
Still no size charts for leadouts.
AMA 656546
« Reply #3 on: July 05, 2014, 07:22:11 PM »
I don't believe that leadouts are required in any event.  Some people hook up direct to the bellcrank without leadouts.  I assume that leadouts are part of the line and therefore subject to the same minimums.
