Speed,Combat,Scale,Racing => Scale Models => Topic started by: Dick Byron on February 22, 2007, 10:41:35 AM
I have just discovered that my source of insulated flying line will no longer ship 300 foot reels. They only have 30 foot, 100 foot and 1000 foot reels. I ordered a 1000 foot reel and will have a lot of extra wire available. It is .018 nylon covered, 60 lb test. I have already made 2 sets of flying wires but always wanted to have extra.
I will make different lengths available in limited supply.
E mail me for pricing for your needs.
www.dickbyron.com
Just to clarify, Dick?
You cite 0.018". Is that the core or the outer diameter?
If it is the core diameter, what is the outer diameter?
Btw, thanks! It's good to know there's now a respected source for appropriate lengths of this line...
Lew,
The outside is .032, the cable is .018 7 strand, 60 lb test.
Surflon (American Fishing Wire Co.) makes insulated leader as follows:
45 lb. seven strand 303 stainless .018 wire dia and .028 total dia.
60 lb. seven strand 303 stainless .021 wire dia. and .032 total dia.
It is available in 100ft, 300 and 1000 ft. spools.
Vic Gearhart
Dang,
That's .004 less than the others.
Chris...
If there is any interest, 4fishen.com lists Surflon in 300 ft. rolls for 30, 45, 60 & 90 lbs.
Vic Gearhart
Thanks Vic,
I should have looked there too. I will have a lot of extra lines but someone will need some someday.
dick
I just put in the surflon lines as leadouts in a Ringmaster..they are so easy to work with..especially when needing a nonslip hold when crimping eyes, etc.
