Speed,Combat,Scale,Racing => Scale Models => Topic started by: Avaiojet on April 19, 2015, 11:35:11 AM
Headline says "frame," but this will hold true with a clear canopy as well. In fact, if you look really really close, you can see the edge of the clear canopy.
Yes I know, you've seen this done a million times so what's once more. LL~
I view the task a bit differently. I want nothing to sand after I spread the mix, in this case, 5 minute Epoxy and micro-ballons.
The taping is important. Alcohol is used to dip my finger in and smooth the mixture once it's in place. I get it really wet. Pulling the tape is all that is left.
Well, I will take a serious look and see if there's areas that need a tad more. Auto Body putty, limited certainly, can offer a cleaner look when applied over the mix.
Filling primer does the same thing. Be nice to have a "edge" at the frame base. Something to follow for that row of rivets.
The results, with only one pass, is something I can live with.
Look Ma! No hands!
I meant, Look Ma! No sanding! LL~ LL~
Decided to press in a bit of Auto Body putty. My mixes are really dry and a bit porous. That was the easiest fix because it was already taped.
Probably a half hour or forty minutes for this task.
Not far from surface detail, plus paint and finish. ;D
Edited: filler to putty.
Friggin amazing Charles. I love the tutorials you do. Even if they have been done before, its great to see how someone else does things. H^^
Awesome detailing, ya gotta start c/l scale or I'm gonna haunt ya.
Dude, that looks absolutely awesome!!!!
Marcus
Marcus
Hey! Marcus!!
You're just too kind. ;D
Can't wait to see your scale project. #^
"Good" Will Hinton,
Hey! Hey! What have you been working on!
