  • July 09, 2025, 08:58:33 AM
Author Topic: First electric scale model.  (Read 10174 times)
Offline victorss
« on: November 22, 2006, 01:40:25 PM »
Attached is a picture  of my first  electric Control Liner.
The B25 is build from the 50S Berkley kit. The modifications include alterating the top turret. removing the bottom turret, replacing the glass nose with a solid one and adding the side and tail gun positions. It has 42 " wingspan  and weighs 3.5 lbs. It has flaps and throttle control. Power is two PJS 800 3D rotating case motors, 2 Jeti 18 amp controllers and 12 320 MAh Thunder Power Li Ploy batteries, one set in each wing. It files well on 53" -- 57" overall -- lines. Control is through a Bill Young Handle. With Master Airscrew 8-6 electric prop the max speed is somewhere around 35 mph. With an PAC electric 8-6 prop the speed increases to about 39 MPH. It is presently being repaired after an accident in my shop.
« Last Edit: November 22, 2006, 02:15:55 PM by victorss »
Offline Darrell Mims
Re: First electric scale model.
« Reply #1 on: November 23, 2006, 08:47:15 AM »
 8)  What no picture of the handle?  Great job  ,I have a old  U-Control B-25 kit with a 47 inch span ,Should be about the same . Thanks for the Ideas .
Offline victorss
« Reply #2 on: November 23, 2006, 09:15:21 AM »
The Handle. It is by Bill Young and has five channels, two of which are only on/off. I have had this one for about five years and have had no problems.
Vic Gearhart
Offline RC Storick
« Reply #3 on: November 23, 2006, 09:27:59 AM »
It's beautiful! Someday I'm going to build a scale plane.
Offline Keith Spriggs
    • khspriggs
« Reply #4 on: November 23, 2006, 11:16:03 PM »
Bob, that would be worth a 300 mile drive to see.
« Reply #5 on: November 24, 2006, 08:27:45 AM »
HI Victor!
Another great looking scale plane!  Like Darrell, I have a U-Control (Japanese kit) B-25 which is all framed up.  Maybe that will be my "entrance" in to "electric"!
Bill <><
« Reply #6 on: November 24, 2006, 09:15:23 AM »
 8)  I have yet to fly with the handle ,but some day soon  ! !    Dude : how are you insulating those wires ?
Offline victorss
« Reply #7 on: November 24, 2006, 09:17:58 AM »
FYI: What I did with the  B-25 was shoot for a target weight between 3 & 4 lbs flying weight. I used a computer program called ElectriCalc and selected motors, and battery pack size based on the program's calculations. The program was nearly right on the money with motor RPM and battery life. The speed is about 10 - 15 MPH less which I attribute to line drag.
When I used the same program for my second plane -- the TA 154-V3 --- the program failed miserably and the motor specs proved to be far more accurate. It is is somewhat overpowered.
My third electric plane is going to be a late model ME110 G with a 63" wingspan with retracts & flaps. I am shooting for a weight of 8-9 lbs.
Vic Gearhart
Offline victorss
« Reply #8 on: November 24, 2006, 09:45:01 AM »
I use Surflon fishing leader. Sevelon (I don't know if the spelling is correct) which is available where I live (So CA) can also be used. I have both lines insulated but only one needs to be. I have been fooling around with coating lines using a flexible urethane but I have not yet got it to where I want it. The advantage is that overall line diameter would be less and line drag less. It is my understanding that Brodak is going to or is stocking insulated line.
Vic Gearhart
Offline Clancy Arnold
« Reply #9 on: November 24, 2006, 02:08:41 PM »
FYI
Brodak is now stocking insulated flying lines.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #10 on: November 29, 2006, 03:31:17 PM »
   OH   BOY! ! !
FYI
Clancy
8)
Offline Michael Boucher
« Reply #11 on: December 04, 2006, 12:41:07 AM »
Very nice B-25.  Glad to see someone using electric power on a scale subject 8)
AMA 59633
