  • June 20, 2025, 06:07:29 PM
Author Topic: F82-15 Profile Scale  (Read 2310 times)
Offline pat king
    • PDK LLC
« on: January 21, 2019, 12:49:16 PM »
The .09 to .15 size F82 Twin Mustang has been updated to be competition capable for Profile Scale. it now carries a scale airfoil.
Pat
Pat King
Monee, IL
AMA 168941
Re: F82-15 Profile Scale
« Reply #1 on: January 21, 2019, 02:26:40 PM »
This has become a more viable subject with electronic throttles.
It would be a real chore with 3-line mechanical throttles.
A few years ago (pre-2.4) I passed on a nice one at an RC swap meet.  I couldn't comprehend retro-fitting the throttles on an already-built Twin Mustang.
Offline pat king
    • PDK LLC
« Reply #2 on: January 21, 2019, 03:24:44 PM »
These F82 airplanes and my F7F Tigercat would be so much easier with 2.4G electronic throttle control.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: January 22, 2019, 08:05:01 PM »
Picture?
If you really want easy, go with electric power!
« Reply #4 on: January 23, 2019, 03:44:01 PM »
Picture?
What would be the point?  Two motors is not twin ENGINE.
Online John Rist
« Reply #5 on: January 23, 2019, 05:06:03 PM »
The point is that it WORKS!!   LL~
« Reply #6 on: January 24, 2019, 10:33:01 AM »
Some people are so picky.  When I was growing up I can't count the number of times people used the term motor when referring to an engine and vice versa.  I guess to be PC(political correct) maybe refer to it as twin power plane. S?P
Also remember some areas can't run piston power because it makes a little noise. D>K
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #7 on: January 24, 2019, 09:45:30 PM »
with 2.4 Ghz throttle control you can use multiple recievers, you can have a receiver in each fuselage and there is a way to have the first receiver power the 2nd one with a single wire.
for glow powered models the best way to set up the throttles is to have one servo per engine with a short pushrod that goes between the servo and engine. the multiple servos then plug in into one or more recievers to the same channel.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
