  • June 16, 2025, 09:35:16 PM
Author Topic: NATS Registration  (Read 3011 times)
Offline Pete Bauer
NATS Registration
« on: June 09, 2022, 09:37:11 AM »
If you plan on attending the Control Line Scale NATS (July 15, 2022 through July 17, 2022), please register ASAP.  The deadline for pre-registration is quickly approaching - June 15th. The AMA uses the pre-registration numbers to determine the number of trophies awarded for each class. Yes, you can still register and attend after June 15th, but it will not add to the number of trophies awarded.
Registration can be found at https://nats.modelaircraft.org/discipline/control-line-scale
Tags: 2022 nats
