Speed,Combat,Scale,Racing => Scale Models => Topic started by: John Witt on November 28, 2010, 11:39:37 AM
I've been thinking again, and you know how dangerous that can be. n~ One of the major problems with my Jenny project was mounting the bellcrank and feeding the flying and (predominately) the pull test loads into the structure, while trying to keep a scale cockpit area.
I've been thinking about the possibility of going to a control handle with an RC stick on it for pitch control and using a system like Clancy's for the elevator as well as the throttle. One of the advantages for scale would be that the elevator servo could be placed somewhere more convenient than in the cockpit where the bellcrank is usually located. Another big change would be one wire to carry the flying loads and a small coaxial or spiral wrapped ground line. The flying wire attachment could be anywhere convenient to the structure, not necessarily in the fuselage, though it would still need to be near or on the vertical CG. I'm considering using an RC-car transmitter handle and using the auto speed-trigger for the elevator and the wheel for the throttle. Clancy's encoder would be substituted for the RF transmitter in the handle.
An added advantage for those so inclined would be some variation of the auto-stability being proposed for stunters. Perhaps a line-pull based system that rolls the model out if the pull drops off, using active rudder and aileron. I could use that in the Jenny for sure. Control of the model wouldn't depend on line tension anymore. Regardless of your feelings about the purity of U-control, such a system could potentially save some nice models.
Anyway, nothing on paper yet, and I would have to build a plane to test the system. Maybe this coming year.
So your "real" problem is that mounting the bellcrank in the fuselage in a position that keeps the leadouts straight makes the cockpit detailing difficult -- yes?
Is there a mechanical solution to this problem? Could you have run the leadouts down from the leadout guides, and put the bellcrank at the very bottom of the fuselage? Granted, in something like a Jenny this still means raising the cockpit floor, but not by much! Could you have used a pulley (or four) and put the bellcrank behind of, or in front of, the cockpit (thus letting you connect the sticks to the elevator control, as well)? If you used light enough leadouts (i.e. flying-wire light), and pulleys, could you have used a drum behind the cockpit for a bellcrank, actuating a pull-pull system for the elevator?
No, actually the problem was solved for the Jenny, but the bell crank is partly visible. Keep in mind, in this case, the pull test is 50lbs, so there is a big load to deal with.
The real problem is for future aircraft, TBD, where the issues are likely different. The loads must be routed into the structure in a way that can be accomodated and still give smooth, bind-free control, etc. The point is that there are more approaches out there than linkages and pulleys. And yes, for the Jenny, I did think about turning the corner with pulleys and attaching the leadouts to the scale elevator cross bar, but pulleys large enough to give smooth control are a worse problem than the bell crank to hide. The pulleys have to take the pull test loads as well as the control anchor point. The result for what I did do is a compromise, but in sport scale the cockpit interior is not judged, I just want it to look scale for my own satisfaction.
For a precision scale project, the requirements are more stringent and the interior appearance is important. The flying wire attachment and the control actuation need not be linked, so perhaps there are two easier problems rather than one difficult one.
Electronic control of the pitch, (elevator), is strictly forbid in control line.
From the general regs:
2. General. A Control Line model is flown on one or more steel wire line(s) or metal line(s) of equivalent strength, attached to the model in a manner providing aerodynamic control of the model’s elevation through manipulation of the control surfaces during flight. Such manipulation of control surfaces, and any other of the model’s operational features, may be accomplished by mechanical means, by electrical impulses transmitted through the line(s), or by any other control system that does not interfere with the control of any other model or present a safety hazard to competitors or spectators.
John, regardless of how you operate the elevator, you are going to have to design the structure to handle the centrifugal (centripital) load on the model. If you go with the servo, and it looks to me like it would be legal, I think you are adding another failure point. Case in point: I lost my R/C sport scale Ki-61 at this year's Nats when the elevator servo failed. Big hole in the Indiana prairie. Any electronic failure is likely to yield a crash with your model. Also in a "panic" situation you might revert to your normal control line style of flying and move your wrist up and down rather than gently press the joystick on your transmitter. As to saving a model when conditions cause it to roll in on you, I have doubts that a rudder or aileron input would be powerful enough to correct and save the model in the space available and at the airspeeds where these problems occur with scale models.
On the other hand, the way we make progress is by guys trying stuff in defiance of the nay-sayers.
Chuck
WOW!! I have been there there and done that. What I know about all this it is legal for AMA. It is not legal for FIA. I have an EXTRA 300S with a Saito 120 4C (big ship). I have a 6 channel controll handle for it. The controll handle sends a signal down the line for ailerons, rudder, smoke, and throttle. The elevator up-down controll is still through a conventional two line system with handle. The only difference is that the bell crank is linked to a pot on a servo driver, not the elevator. The servo driver drives two servos for the elavator (300S has a split elavator). This in fact acts as a power assist for elavator control. This is important when at low throttle. All you need is enough line tension to run the pot. Works great. Advantages are easy to hook up. Servos provide muscle to overcone pushrod drag. Works with low line force. Disadvantage is more stuff to go wrong. Also weighs more. You need a big battery on board to run all of the electronics. With this setup I can do a pre-flight for the judges. Waggle ailerons, rudder, etc. I can steer on the ground for taxi manuvers. SO far I have not had a system failure.
Picturs shows the boat load of servos. Not shown are the two servos in the wing. It also shows the control head that goes on the handle.
I too had thought of a chest harness with a cable between the aircraft and harness to handle the centrifugal force. All functions would come from a gutted RC control box held in both hands RC style. The box would talk down the a twisted pair of wires supported by the teather cable. You could actually do slack line maneuvers. It would fly like a RC that is limited by a 60 ft pair of lines.
For instance, one of the candidate airplanes I'm looking at is a TBM Avenger. This model has a huge greenhouse through which a great deal of the interior may be seen. If I want to have a realistically thin fuselage section, it will be difficult to put in enough structure to hold the pull test loads. If one anchors the flying wires at the wing root, a lead attachment near the wing tip that is offset to put the flying line in the right vertical position would feed all the loads into the airframe in much the same way it is accommodated in the real airplane, ie, through the whole wing root. This could perhaps be done mechanically as well, not to put a cap on anyone's ingenuity.
How about a Cub, with open cockpit doors and the lead attached to the struts. Maybe a P-40 with the lead attached to the bottom of the wing tip. It seems to me there are a lot of advantages for scale planes to not having to deal with the traditional leadouts that run into the fuselage.
As to the control confusion, that is solved by putting sufficient practice (always an issue with scale models). And crashes will probably always be with us for one reason or another. What I'm proposing less complex than the average 6 channel R/C plane. Reliability is achieved with careful design and scrupulous maintenance.
We'll see. I haven't found any real gotcha's yet, and it is interesting. And I'm not the first to think of it anyway -- see John Rist's post.
For what its worth John, as scale judges we are instructed by the rules not to downgrade forany intrusion the controls make to the models lines.
And I think you may fight an uphill battle with controling pitch by RC even if it is in the lines, but do it as you see fit.
Could be an issue getting the control rate such that the pitch control has the right gain for the model: there's still something for us mechanical guys to work out. There are a bunch of different servos out there though, and the problem is not much different than the control rates and resolution required for landing an RC plane. I guess it's time to do more concrete planning and try it out. My crashed Vector might make a good test bed. I already own most of the other stuff.
I'll keep ya'll posted.
Control rate is not a problem. As it turns out the elevator pretty much tracks the handle. Scale aircraft generally don't fly a stunt pattern. Loops and wing overs maybe. If you think about it elevator movement is quite slow for scale flight. Amount of throw is controlled same as in RC. You change the length of the servo arm and the length of the elevator horn. And of course the spacing of the wires at the handle. If you are going to drive the elevator with a stick controll at the handle it still won't be a big deal. Move the stick and adjust the length of the servo arm and the length of the elevator horn till you get a reasonable elevator throw. The other cool thing if you also have throttle you can always land if thing are not right.
You are certainly within the rules to build the proposed model.
However, the recurring complaint about a 50-pound pull test is unfounded. The Scale catagory has a pull test requirement that is well on the light side of actual safety. If your Scale job is so big & powerful that your pull test is 50 pounds, it probably should be 80.
Take a look at Carrier, Speed, and Racing. Event Stunt for that matter.
One bit of advice. Don't anchor the system to some sort of body harness. Your shoulder and wrist provides a shock-absorbing mechanism to cushion the jolt when the line goes slack and then tight again. This fact is also the key flaw in "outside-the-circle" piloting contraptions.
Actually, I didn't intend to sound like I was complaining about the pull test. It is a requirement that must be dealt with.
The Jenny weighs 10.3 lbs, and its actual in flight pull is about 7-10 lbs, so no harness required. I've never considered using a harness to hold a model, I think that I wouldn't let myself in for anything that would pull that hard. It's easy to calculate approximately what the pull would be ahead of time and adjust your speed/weight target accordingly. At that weight, it falls within the 5G pull test range, giving 50 lbs.
John, thanks for your comments about the controls. I never found it difficult to get to a good set up when flying RC, so don't think it would be too hard for U/C. All the usual things apply, a straight model, correct CG in all axes and one should be able to reach a viable set up with some testing. As you say, with throttle, you can always slow down and land.
(Thinking out loud here:)
One problem with the Jenny that you won't have with a lot of other planes is the thin wings -- on most later planes you'd be able to bury your bellcrank in a wing, assuming that you could get the wires to it. Even if the wing were in an inconvenient spot, even if the fuselage still needed to be mostly open, you could at least do the mechanical force multiplication and conversion to a push-pull in the wing, and trim down the necessary hardware in the plane tremendously.
With one cable to the plane, you could make a four-into-one harness at the outermost "N" strut to put the G load on the wings, and route the electrical signal as you see fit. That still leaves you with servo mounting, but I think that's been well discussed. Some sort of handle arrangement that still left the elevator control working by tilting the handle would be cool, but that's fraught with problems.
Personally I think I'd prefer the simplicity of direct mechanical control -- this is for me personally, and not a prescription for you: if I'm gonna put a bunch of servos and electronics into a plane, and sever my direct connection to it anyway, I think I'd just make it RC.
I just had a brain wave.
I know that you're looking for an electronic solution, and I know this isn't it. But with all those wires and struts that abound in a Jenny anyway, you could bring the control lines to a bar (essentially the bellcrank, only disguised) in the rigging, and bring push-pull elevator cables off of the bar, have it all hanging out in the breeze, and maybe not have it look that bad!
Note that this is idle poofery -- challenge me to do it, and I'll say "when I build a Jenny". Then I'll say "when I build my second Jenny". Then you'll notice that I predominantly build fast things for control line, and you'll feel cheated.
Hadn't thought about the shock-asorbing part of a harness. I suppect that a spring shock asorber would be in order.
One of the things I like about U/C is the direct touchy-feely of the handle in my hand. I do away with that reluctantly. What I've been thinking about here is a way to solve some of the more difficult packaging problems with various scale planes. I think John has proven it's a viable way to try.
I think the following should warrent consideration. It is a small part of the best description of Control Line flying I have ever read.
"It even provides an automatic levelling action. In level flight if the arm is raised or lowered, the model will follow suite until it is level with the arm again. See below. Although this illustration is to show how to approach a first flight, the principal is the same, If the handle is held in a fixed position and the model rises, the bellcrank will start to feed in down elevator. The reverse applies if the model starts to loose altitude. The intensity of this effect depends on a number of factors, and for the beginner, may feel like it does not happen at all, but be assured, it does exist."
The full text is at:
http://www.fuelsoaked.me.uk
Click on the C/L Explained tab.
I buried the bellcrank in the wing of my Spacewalker and built a raised ball link to protrude just enough to allow the pushrod wire to skim along the surface of the wing. The cockpit floor hid the wire neatly.
One thing to remember is that it is not where the bellcrank is mounted that sets up how the model flies. It is the location of the line guide in relation to the CG of the model.
In the first picture I am adjusting the vertical location of the line guide to fly wings level. My garage was almost not tall enough to do this.
In the second picture I am adjusting the horizontal location of the line guide to have the nose hang slightly nose down. I learned this from Jack Sheeks.
Clancy
