  • July 08, 2025, 10:38:39 AM
Author Topic: DO-335  (Read 14385 times)
Online John Rist
DO-335
« on: August 09, 2013, 02:01:20 PM »
Well my DO-335 is out of paint.  Next a ton of work with the ink pin and add decals.  It will be close for FCM this year.
Re: DO-335
« Reply #1 on: August 09, 2013, 02:22:51 PM »
Looks awesome so far.  Dare I ask about weight?
Online John Rist
Re: DO-335
« Reply #2 on: August 09, 2013, 06:03:09 PM »
It's heavy but with two TDs churning it should go!
 LL~
Just weigh the DO-335.  It looks like 23-24 oz.  However it has a 24" wing span and approximately 120 sq in so it should fly OK.
« Last Edit: August 09, 2013, 11:25:14 PM by John Rist »
Online John Rist
Re: DO-335
« Reply #3 on: August 13, 2013, 02:37:26 PM »
Decals generated and applied.  Ready for clear coat.  Next step is install two Cox 049, prop shaft with rear bearing, and fuel tanks.  Question? Is it legal to remove fuel tanks for scale judging?
Offline chuck snyder
Re: DO-335
« Reply #4 on: August 13, 2013, 04:56:29 PM »
Don't know about the 1/2a rules in various places, but in all the other events it would be illegal to remove the tanks. The rules are very explicit about what can be changed.
Offline Mike Keville
Re: DO-335
« Reply #5 on: August 13, 2013, 06:18:29 PM »
If you were to bring it to our 7th annual 1cc event here in Tucson, Oct. 12-13 (and I wish you would....it's a beauty!) the tanks should be left in place.
Online John Rist
Re: DO-335
« Reply #6 on: August 13, 2013, 08:40:48 PM »
That's what I thought - I will just paint them to match.
 y1
Online John Rist
Re: DO-335
« Reply #7 on: August 13, 2013, 10:30:58 PM »
Wish I could but it is 1616 miles from my house. That's 6 days travel time by car  Total trip time is 10 days.  Maybe some day but not this year.
Online John Rist
Re: DO-335
« Reply #8 on: August 14, 2013, 03:18:23 PM »
Well my DO-335 is ready for engine test running.  The big concern is will the rear motor drive the prop shaft.  Will post results.
Online John Rist
Re: DO-335
« Reply #9 on: August 14, 2013, 03:19:27 PM »
More ready for test run.
Offline jim gilmore
Re: DO-335
« Reply #10 on: August 14, 2013, 06:43:06 PM »
Thats a work of art. I sure hope it flies as good as it looks
. H^^
Re: DO-335
« Reply #11 on: August 14, 2013, 09:34:18 PM »
 That's really cool, nice job. Don't be surprised if a .40 sized version pops up somewhere at some point. VD~
Online John Rist
Re: DO-335
« Reply #12 on: August 15, 2013, 04:56:00 PM »
Well I just finished test running the two engines.  They ran really good.  I am not sure what you would call them.  They are a mix of parts.  The rear started out as a Medallion .049.  It now has an after-market aluminum housing that replaced the red plastic housing.  It is also sporting a brand new product engine piston and jug.  The front started out as a TD .051.  It has an after-market aluminum housing that replaced the red housing.  It also is sporting an after-market venture that has a micro set needle.  And last but not least it has a brand new product engine piston and jug.  They seem to be happy on 15% fuel.
My first test run lasted for about 2 minutes should be long enough for 10 laps.   On the test run the front quit first.  I hope to adjust everything so that the rear quits first.   However with the inline engines it doesn't matter.  It should fly on either engine well.  If all goes well I hope to test fly tomorrow or Saturday.
Offline Jeff Traxler
  • T-Bone
Re: DO-335
« Reply #13 on: August 16, 2013, 12:44:29 AM »
That little bugger looks great.I'll be at the FCM and can't wait to see it fly.
Re: DO-335
« Reply #14 on: August 17, 2013, 08:37:59 AM »
If the plane flies as well as it looks in the pictures and your documentation is up to snuff,  you have winner.
Online John Rist
Re: DO-335
« Reply #15 on: August 17, 2013, 10:52:32 AM »
Well as the old saying goes we want 70 deg temp, no wind, and no rain for a test flight.  Today was such a day except for the no rain.  Well it wasn't exactly raining but it was misting.  A mega thanks to Rollin Keszler for coming out in this slop to be my pit crew and take picture of the first flight of my DO-335.  #^ H^^
Now for the flight report.  She flies great!  The take off was a little rough.  I tried to lift too soon but it made it into the air.   It is a bit of a lead sled and will need 3/4 of a lap to come up to flying speed.  In other words Requires a true scale rollout on take off.  Once airborne it was stable in level flight with good line pule.   At 30 laps the front engine quit.  She made a smooth landing on one engine (rear).  Taxied for about 2-3 laps and the rear engine quit.  All in all a really good flyer.
Photos courtesy of Rollin Keszler:
« Last Edit: August 18, 2013, 12:11:22 PM by John Rist »
Offline jim gilmore
Re: DO-335
« Reply #16 on: August 17, 2013, 12:03:25 PM »
Out of curiosity. Are you saying with only one engine it would not have flow for a few laps ??
Reason I ask this is i had a sterling p-38 . the 1/2a one and the one time i flew it the engines were very rich and it rolled almost 3 laps before they leaned out and it flew ....though I think that was the only time I flew that model.
Online John Rist
Re: DO-335
« Reply #17 on: August 17, 2013, 12:24:33 PM »
The front engine is stronger than the rear.  The rear is turning that big U-joint and prop shaft.  It might fly on the front only but with rear only it would be a struggle.  Anyway landing and taxi on one engine was cool!
Re: DO-335
« Reply #18 on: August 17, 2013, 01:27:06 PM »
Great John!  I think I might be able to make the FCM on Saturday after all, so bring plenty of fuel and conversation with you!!!
Re: DO-335
« Reply #19 on: August 18, 2013, 07:58:45 AM »
That is great news about the plane.   Now go show them at the FCM contest.
Online John Rist
Re: DO-335
« Reply #20 on: August 18, 2013, 09:14:24 PM »
To soon to tell but the weather looks good for the FCM @ the AMA August 24, 25 2013.  SO the plan is for me and my wife Peggy to make the trip.  I will bring 3 airplanes.  My electric 576 Ringmaster, my Extra 300S, and my DO-335.  Hope to get in some fun flying with the Ringmaster on Friday. I need to learn the novice pattern.  Right now I have attempted everything but the overhead 8.
What time does the scale contest begin on Saturday?
Re: DO-335
« Reply #21 on: August 18, 2013, 11:13:33 PM »
 John,
 Just curious, what length/diameter lines are you using?
Online John Rist
Re: DO-335
« Reply #22 on: August 19, 2013, 06:24:14 AM »
John,
Dornier Do-335
Scale = 1/22.5
Model wing span  = 24"
Model Power:  Two Cox TD .049
Model weight:   23.5 oz  (1.46 lb)
Line set:  .010" x 2 x 38'  SS Braided
Pull Test:  1.46 lb x 10 = 14.6 lb  ( 14 lb, 10 oz.)
  • T-Bone
Re: DO-335
« Reply #23 on: August 20, 2013, 02:13:03 PM »
Hi John,I think around 8 AM.Allen likes to get things going early.I am going down to Muncie on Thursday to practice and will be glad to help you with that  overhead 8 Friday if you would like.I am camping at the AMA so I won't be hard to find.Trax
Online John Rist
Re: DO-335
« Reply #24 on: August 20, 2013, 08:16:31 PM »
Trax,
What does you camper look like?  Will you be in the RV hookup lot or the camping area? I will also be traveling Thursday.  I have a Coleman camper that has been converted to a one room toy hauler.   It is no longer a camper but an EZ-UP on wheels.  I will probably park it at the L pad. For me ruffing it is a lumpy bed at a motel.
  • T-Bone
Re: DO-335
« Reply #25 on: August 20, 2013, 09:44:17 PM »
John,Ill be at the primitive camoground.I have a transistor radio and a flashlight.All the juice I need.I drive a white Dodge Dakota with a cap.
Online John Rist
Re: DO-335
« Reply #26 on: August 21, 2013, 02:36:15 PM »
Well this will be my final post before I head out to the FCM @ AMA.  A converted, very old, Coleman camper makes a great toy haler.  I have about $600 total in the rig.  That includes new wheel hubs (and bearings), new rims, and new tires.  It was a ton of work to convert but hay shop time is quality time.
The black covered thing on the front is a 3 KVA generator.  The air still works and I have power for charging batteries.
Re: DO-335
« Reply #27 on: August 22, 2013, 08:34:26 AM »
And a place to sleep when the planes are rearranged it looks like.   Have fun at the FCM Contest.
Online John Rist
Re: DO-335
« Reply #28 on: August 22, 2013, 07:00:43 PM »
Works for me - BUT the wife needs a motel
 LL~  LL~
Online John Rist
Re: DO-335
« Reply #29 on: August 23, 2013, 05:58:19 PM »
Had trouble getting in a test flight - object on the runway!
 LL~   LL~    LL~    LL~
Re: DO-335
« Reply #30 on: August 24, 2013, 10:12:08 AM »
Don't get them upset.   I had the same problem flying off an athletic field while attending a company school.    But, they would mosey away once I started the engine and once I landed would resume their activity.
Online John Rist
Re: DO-335
« Reply #31 on: September 05, 2013, 06:00:51 PM »
Well the DO-335 is underpowered.  I bought a NV AMD 061CL to put in the front.  Am bench running it right now. It appears to quit a bit stronger than the TD it will replace.
 n~
Re: DO-335
« Reply #32 on: September 05, 2013, 06:51:19 PM »
Good idea John, but I also think you could use more torque for the rear one to turn all that hardware.  I loved watching the ship fly, it is well worth more work!!!!!!!!!!!!!!!!!!!! y1 y1 #^ #^
It was also great to chew the fat and get to know you better.
Online John Rist
Re: DO-335
« Reply #33 on: September 07, 2013, 09:52:01 AM »
Well the DO-335 with a Norvel 061 setup is ready for it's first test flight.  The NV AMD 061CL with a Cox 5x3 3-blade, on 30% fuel is turning 20500 RPMs.  The back engine, a TD 049 on a Cox 5x3 3-blade pusher and 30% fuel is turning 14000 RPMs.  I still have 3 head shims in the AMD 061.  But it runs so well that I will try it this way.
Monday is test flight day.  Will report.
Re: DO-335
« Reply #34 on: September 07, 2013, 11:46:58 AM »
Good luck with the tests flights, John.  It is looking great!
BIG Bear
RNMM/AMM
Online John Rist
Re: DO-335
« Reply #35 on: September 09, 2013, 06:36:31 PM »
It works!!  The Norval AMD 061 has great power.  The DO-335 is now a contender!
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: DO-335
« Reply #36 on: September 09, 2013, 07:48:29 PM »
Awesome John, Good to hear everything worked on the model!
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Re: DO-335
« Reply #37 on: September 10, 2013, 08:38:34 AM »
Great news,  now go get em.
Re: DO-335
« Reply #38 on: September 12, 2013, 02:41:19 PM »
Excuse my ignorance, but how many laps are required to be flown with all engines running to get the multiple engine bonus?
Thanks!
Online John Rist
Re: DO-335
« Reply #39 on: September 12, 2013, 04:03:37 PM »
Thanks!
It depends on the contest.  At St Louis all aircraft must be a twin 1/2 A thus no bonus points.  It is flown under local rules.  I am looking for my copy of rules.  They have a minimum  number of two engine laps to be an official flight.  Not sure how many.
AMA 1/2 A scale rules provides 10 points for up to ten laps (1 point per lap).  They also provide 0 to 40 points for realism and smoothness of the flight including the landing.
Their is a five point multi engine bonus "provided the additional engine(s) run during the majority of the flight (excluding landing)"
SO what's the majority of laps.  Say if I fly 10 laps - I need 6 laps to qualify.  If I fly 20 laps I need 11 to qualify.   What I am guessing is that they will quit counting after ten.
FCM goes by AMA rules.
I have no clue on the Texas 1/2 contest.
Re: DO-335
« Reply #40 on: September 12, 2013, 09:32:33 PM »
 Among others I'm anxious to check out this model next weekend. I'm planning on making the trip down from Minnesota, getting to the Pear Tree on Thursday afternoon. ;D
Re: DO-335
« Reply #41 on: September 13, 2013, 10:33:10 AM »
We talked about the rules at the St Louis club meeting last night. The number of laps came up and the majority vote was 10 laps also.
Give Bob Arata a call (look in the events section for his phone number) and he can give a full run down of the 1/2a rules.
Fred Cronenwett
Fred Cronenwett
Offline SteveMoon
    • www.ultrahobbyproducts.com
Re: DO-335
« Reply #42 on: September 20, 2013, 12:42:18 PM »
That is a great looking plane, super cool!
Re: DO-335
« Reply #43 on: September 20, 2013, 12:56:19 PM »
Hi John,
As I have said on other occasions, I think the model is awesome!  A very good exercise in "engineering".
I hope to get to see you, and your models, while we are all still around.  I think you come up with some great subjects and execute them very nicely.
BIG Bear
RNMM/AMM
Re: DO-335
« Reply #44 on: September 20, 2013, 07:13:19 PM »
I would love to be able to be there and see this magnificent machine fly. I'm just proud to have been able to contribute to your threads when you were sorting out your engine setup.
Good luck, John.
Rusty
Re: DO-335
« Reply #45 on: September 21, 2013, 11:12:46 PM »
 John,
 Didn't see you and the Do335 in St. Louis today. Thought you were coming?
Online John Rist
Re: DO-335
« Reply #46 on: September 24, 2013, 03:34:06 PM »
John,
Sorry about that- something came up.  Besides he current DO-335 is a lead sled.  I have started version 3 - hopefully light enough to fly better.  The current one doesn't like wind.  Am aiming for next year.
Online John Rist
Re: DO-335
« Reply #47 on: November 21, 2013, 03:39:00 PM »
The new shaft for the 3rd generation DO-335 came in today.  It was fabricated by Lee machine shop and it looks great.  It has been fitted for a Norval .061 instead of a TD 049.  It is 1" longer than the old shaft and weighs less.  As always great job Lee!  The goal for the third generation DO 335 is weigh 1/2 of what the old one weighs.  It also is sporting a new high lift air foil.  I am hopping it may possibly do a loop.
Offline MarcusCordeiro
Re: DO-335
« Reply #48 on: November 29, 2013, 06:29:55 AM »
That is a very cool design...
Like it!!!
Just don't forget a vídeo of the new one... ;D ;D
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Online John Rist
Re: DO-335
« Reply #49 on: December 29, 2013, 02:20:25 AM »
Finally worked out the controls for the elevator.  Rear motor shaft is in the way for the normal torsion rod between halves.
