  • June 18, 2025, 07:05:10 PM
Author Topic: Tucson's 2014 1cc results...  (Read 3341 times)
Offline Mike Keville
« on: October 12, 2014, 05:22:33 PM »
...can be seen in the 'Contest Results' section, below.
Re: Tucson's 2014 1cc results...
« Reply #1 on: October 17, 2014, 05:38:01 PM »
Ted Kraver sent a disc full of pictures from the 1/2A contest here in Tucson last weekend.
« Reply #2 on: October 17, 2014, 05:40:37 PM »
More.
« Reply #3 on: October 17, 2014, 05:46:57 PM »
 Very cool stuff, thanks for the pics. The overall lineup impresses me more than the entire group in the scale class photos I've seen from the NATS. y1
« Reply #4 on: October 17, 2014, 08:50:09 PM »
In the 2nd set of pix, above, you'll see a Tupolev TU-95 'Bear'.  That was Keith's winning entry in Tucson's first event, 2007.  It performed flawlessly.  I used to have a great in-flight photo of it, but can't seem to find it now.
« Reply #5 on: October 20, 2014, 11:25:13 PM »
So what, now? Keith has built a B-47, Bear, XF-11, Rainbow, Mistel, and Whirlwind?
Are the Owl and HE-177 LeRoy's?
Cool, I've got to get out there again. Work's getting in the way of my day's off.
Chris...
« Reply #6 on: October 21, 2014, 05:14:08 PM »
. . . Are the Owl and HE-177 LeRoy's? . . .
Yep.  Also the ME-110 and BV-138.
« Reply #7 on: October 21, 2014, 06:03:40 PM »
So what, now?
 A B-36 with six pushers and four Jetexes! ;D
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #8 on: October 21, 2014, 07:14:50 PM »
my vote would be the Short Sunderland or Boeing 314 flying boats
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #9 on: October 21, 2014, 08:12:29 PM »
"So what, now?"  (re: Keith's plan)
<chuckle>...I could tell you, but you wouldn't believe it.   :o
« Reply #10 on: October 21, 2014, 08:42:08 PM »
 With Keith that's a real tough one to guess. Whatever it is though it will work, and it will also be extremely well done.
 The sad thing for the rest of us is that it's a loooong time 'til next October! ???
« Reply #11 on: October 21, 2014, 09:28:04 PM »
Next October is plenty of time to get something built.  Models can be sent to be proxy flown.  Builder does not need to be here.  In the past, there have been models at this Tucson contest that have received trophies being proxy flown.  There are several pilots here that can be deemed adequately experienced with CL models to do the proxy task.  However, not mentioned in the proxy pilot rule here is the basic assumption that the airplane has been flown with all the engines operating before sending it here.
Stand by for some "slight adjustments" for the Tucson rules to be announced soon.
Jim Roselle
« Reply #12 on: October 22, 2014, 05:35:16 AM »
Keith,
Are you bringing your plane up to the Phoenix contest this weekend?
Jim
« Reply #13 on: October 22, 2014, 09:32:11 PM »
 ...what I meant by that Keith is that it's going to be a long time before your next masterpiece is revealed.
« Reply #14 on: October 22, 2014, 11:44:47 PM »
OK, thanks for the comments.
I had several ideas lined up for the next several years, but the rules changes being considered sort of changes what will be next.
Nevertheless, build something quick and easy and have it proxy flown.  One of the changes being considered is a "Perpetual Plank Award".  It can be a model built for either of our categories - Limited and Unlimited.  But the would have to be completely from sheet balsa with a limitation on the thickness of the sheets.  The award will be for the best "Plank".  Sort of a throwback on what people used to think of when 1/2A profiles were mentioned.  Standby.
Keitih
« Reply #15 on: October 23, 2014, 05:22:34 PM »
 I appreciate the proxy suggestion, and have always been aware of that option, but if I was going to get involved I would want to be there and fly my own model. No offense to any potential proxy pilots, that's just how I would want to do it. Along with being there I would also get to enjoy seeing everyone else's models and flights, that would be just as fun and entertaining to me. Maybe someday, just gotta hit the lottery so I can afford the trip. :(
