  • June 30, 2025, 10:24:28 PM
Author Topic: 4 blade scale prop for 1/6 mustang  (Read 1864 times)
Offline Bruce Perry
« on: April 30, 2020, 01:45:04 PM »
I'm inerested in a solution for a 4 blade scale FLYING prop on a 1/6 Mustang.
simply does something exist?  I've seen some RC models with scale flying props and I'd like to use one on this project.
Any Ideas?
Bruce
Re: 4 blade scale prop for 1/6 mustang
« Reply #1 on: April 30, 2020, 02:09:00 PM »
Any Ideas?
Bruce
Bruce,
I've seen those props on line for Electrics.
I would Google the scale ARF Warbirds. This is where I've seen these scale props that can actually be used. And the props are available as a part.
Someone else recently had a similar request, I believe I responding the same way?
Good luck.
CB
« Reply #2 on: May 01, 2020, 10:22:49 AM »
Any Ideas?
Bruce
A true flying scale prop for a plane like that would demand a 6-to-1 reduction gear to get the prop RPM to accept the engine RPM.  Since the early 1930's, all airplanes except the cheapest Piper Cubs and Cessna 150's used geared props.
I made one for my Bearcat - static only.
« Reply #3 on: May 22, 2020, 10:51:18 PM »
Maybe ; http://impscale.com/html/mustangs.html .
76 in span . The Wing. Not the Prop .  :-\
« Reply #4 on: June 03, 2020, 09:02:38 PM »
The largest I've seen is for 1/8th scale on the foam scale models with plastic props. 60 inch wingspan Mustangs are common now with 4 blades for electrics that actually have decent thrust. I plan on one for my 6S powered 60" Red Box Top Flite Airacobra.
Chris...
