  • June 17, 2025, 09:57:26 AM
Author Topic: Extra 330 SC Documentation paint scheme  (Read 2497 times)
Offline Walter Hicks
« on: June 10, 2017, 04:27:11 PM »
Does anyone know here I can get documentation for an Extra 330 SC? Bob Banka does not have any that I can find. I also am looking for a good paint
scheme. The one I like is very complicated. (Jeff Boerboon , red ,white and blue)
Re: Extra 330 SC Documentation paint scheme
« Reply #1 on: June 11, 2017, 02:49:22 AM »
Walter,
Here's a link to a Forum where you can get everything you need to build that fine model.
http://forum.largescaleplanes.com/index.php?showtopic=59158
I hope the link works.
Also, your eyes are fooling you, that paint scheme is actually quite simple.
With a white base coat and the correct/accurate masks, it's not a task at all. A bit of work to get the masks correct because the scheme is dependent on correct masks and the placement of them, but no big deal with the purchase of the 1/32 plastic kit offered.
The plastic kit is a killer.
The kit has it all, great 3-views AND a "paint mask" sheet to boot!
I hope my reply is helpful for your decision to take the project on.
I can help you get through it.
Good luck.
CB
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #2 on: June 11, 2017, 11:56:48 AM »
check out www.airliners.net and under the photo search look under "Extra 330 SC" and you might find something that works for you. Or do a google image search and see what shows up
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #3 on: June 25, 2017, 07:11:33 PM »
Thank you all for the responses. :)
